Poly Wall anybody use it
dedubya | Posted in Construction Techniques on June 2, 2009 08:30am
 I have a prospective customer with two  leaky block walls,The building is set into a sloping hillside with the back wall and one end wall approximate. 32″ below grade the water is coming from under the first course of a  below grade cut face cmu wall, under sized gutters/ downspouts , poor grading, and clay soil all have impact on this project.
The bid I am working on involves excavating down past the footing , pressure washing the wall, having Poly Wall applied, and installing a  foundation drain system around the outside perimeter of both below grade walls,kind of like what was diagramed in this issue of FHB magazine.
The question is ,is anybody familiar with or used the sprayed on Poly wall system. I know it is more pricey that an asphalt based waterproofing  but it seems to me that it would fit this application better than  the asphalt sealer, or the rubber/black sheet systems I have used in the past. Because of the rough uneven face of the cut block wall.Is there any downside ? except the cost involved.
                                      Thanks D.W.
  1. dedubya | Jun 02, 2009 02:44pm | #1
    bump
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
