Guys, I am back to an old project of getting rid of the old fiberglass panels on my carport. I would like to do double wall polycarb flat panels. I have 24 on center rafters. Anyone have install hardware they like that looks good and does not leak? I have see some stuff that is like a standing seam on a metal roof.
There's a constant source of clean water for you to use, and all you have to do is collect it.
THey supply an "H" or back to back "C" for the long seams. And don't forget to alum tape the open ends ( short sides) before slipping on the "C" caps.
The Neoprene washer hex head screws are what work well for the screwing down.
I have seen some where there is incorporated into the H moulding a clip, and its like a little cap over the seam. Ring any bells?http://www.etherhuffer.typepad.com
Not that I have used, but I have only installed 2 projects and I used what was supplied, I had no say in the matter.
