Searched the archives to no avail. After reading the info in the store, it seems like this stuff is almost as tough as kryptonite, but I don’t know anyone who uses it. I have to caulk the joint between a glass block window and the tile in the jambs. In a shower. Used silicone for the sill, but wasn’t very happy with the end result. I am wondering if poly is adequate for the job? Also can you tool it off with a wet finger like latex, or is it more like silicone?
Thanks. wedge
There's a constant source of clean water for you to use, and all you have to do is collect it.
Searched the archives to no avail. After reading the info in the store, it seems like this stuff is almost as tough as kryptonite, but I don't know anyone who uses it. I have to caulk the joint between a glass block window and the tile in the jambs. In a shower. Used silicone for the sill, but wasn't very happy with the end result. I am wondering if poly is adequate for the job? Also can you tool it off with a wet finger like latex, or is it more like silicone?
Thanks. wedge
