In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
pool construction
| Posted in Construction Techniques on June 5, 2005 05:09am
I’m having a vinyl in-ground pool currently being built in my backyard.  The excavators came in on Friday and started digging.  We now have the 20 x 40 excavated hole (actually larger) but we also have the deep end almost filled with ground water.  The pool guys are coming in tomorrow (Monday) and were supposed to start the actual pool build.
What do we do now?  Can we still build the pool?  What do I have to watch out for with the pool company to make sure that the pool they build will not be washed away in a couple of years?  Is therre any special technique that is needed now that isn’t needed during a normal pool build?  Are there any additional costs that I’m going to be hit with because of this?
I really need help with this. Thanks
  1. FastEddie1 | Jun 05, 2005 06:44pm | #1
    I don't know the answers, but i have a couple of questions.  Will the vinyl liner be placed directly against the exposed soil?  Or will there be a cushion between the liner and the soil.
    1. r_ignacki | Jun 05, 2005 06:55pm | #2
      Ones Ive seen installed go on top of a sand bed, with the top edge of the liner tucked in some type of metel reglet between the copings and a concrete apron around the perimeter.
    2. RichardM | Jun 05, 2005 07:00pm | #3
      underneath the liner will be concrete and under that will be gravel, then soil
      1. Piffin | Jun 05, 2005 08:39pm | #5
        If they are a pro company that has done this before in your area, they will be prepared and have a pump with them. But a call to the office to leave a message suggesting such would not be out of order - "Hellop, I thought you'd need to know that there is some water in the bottom of our excavation and that your crew will probably need a pump come monbday morning. You would be better off staying out of the hole, because it could have become unstable at the sides and you would cause a cave in, adding to their work and possibly putting yourself in danger.
    3. dIrishInMe | Jun 05, 2005 07:14pm | #4
      Around here they dig a hole, install either a galvanized steel or composite material that bolts together and forms the structure of the walls and supports the top edge coping, pour concrete behind that, then line the bottom portion with hand installed lite-weight concrete, and then install the liner.  Not sure what the exact composition of the lite-weight concrete is (comes in a bag) but I think it uses something similar to vermiculite for aggregate.
      Matt
      Edited 6/5/2005 12:16 pm ET by DIRISHINME
  2. BobKovacs | Jun 05, 2005 11:00pm | #6
    They need to install a hydrostatic valve in the bottom of the pool (presumably in a concrete base below the liner.  This valve will normally be closed, but when you drain the pool, it will be opened to allow groundwater in.  Without the valve, the groundwater pressure below the pool shell will pop the shell out of the ground if the pool is drained (the water pressure of the filled pool holds it down normally.
    To be honest, I've never seen this done with a vinyl lined pool, but we used to run into high groundwater in one area of Las Vegas where I build several hundred concrete pools.
    During construction, they can sink a small pump in a stone pit below the shell- this will keep the hole dry during construction.  We used to just shotcrete right over the the pump, and patch the hole when we plastered.  The pool was filled immediately to cure the plaster, so there was no time for groundwater to seep in.
    If they've been around for a while, I'm sure the pool company has run into this problem before and will know how to handle it.
    Bob
    1. RichardM | Jun 05, 2005 11:37pm | #7
      Bob,
      Thanks for your reply.  I'll talk to the pool guys tomorrow about this.
      Does the pump need to be on after the pool has been installed?
      1. BobKovacs | Jun 06, 2005 01:21pm | #8
        "Does the pump need to be on after the pool has been installed?"
        The pump has to run until the pool is filled.  Once there's water in the pool, the weight of the water negates the upwards pressure of the groundwater.
        Bob
        1. RichardM | Jun 07, 2005 07:24am | #10
          what about long term effects of the ground water around the pool?   are there any different building materials that we should be considering for our vinyl pool?
          1. BobKovacs | Jun 07, 2005 01:25pm | #11
            Not really sure of any long-term effects, though I'm not a big proponent of vinyl pools to begin with.  A concrete shell would be a better choice IMHO, but it would still need the hydrostatic valve.
            Bob
  3. maverick | Jun 06, 2005 03:37pm | #9
    You'd be surprise how many people drain a pool to do maintenance only to find it float out of the ground. An empty pool is just another boat
  4. paperhanger | Jun 07, 2005 02:57pm | #12
    Had 2 pools put in, both had high water table problems, like yours. They will put in a blind drain. They fill the deep end with crushed stone , put the drain in and shape it to the specs of liner. Then they put vermiculite on top of the stone, shape that and add the liner. All this time the pump on the blind drain is running. After the water is added, they will disconnect the pump and you will have a pool. The pool water will equalize the pressure from the ground water and the pool will not heave. Mine is doing just fine and is about 75 degress right now. Guess I'll jump in now! ENJOY YOUR POOL!!!!
Using Liquid Flash at a Wall-to-Foundation Connection
Brian Pontolilo demonstrates how to air-seal where the concrete foundation, mudsill, and ZIP System sheathing all meet.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
