Poor quality shower enclosure install
FastEddie | Posted in General Discussion on January 5, 2009 05:38am
We spent the holidays with daughter in San Antonio, and I had a “honey do” list, as always.  Even though it’s a rental, there’s always something.    Shower drips in tha master bath, so i was trying to figre out if i could simply tighten the packing nut, but that didn’t work.  Anyway, here’s what i found when I pulled off the escutcheon, which had been 100% silicone sealed to the fiberglass with no weep hole at the bottom.  house was built about 2004 by a local big time tract builder.  It’s obvious that they cut a lot of corners when the built the place.
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. davidmeiland | Jan 05, 2009 05:41am | #1
    What, you don't bust open fixture holes in fiberglass with the claw of your hammer?
    JeffBuck | Jan 05, 2009 05:41am | #2
    rough hole 'er a fancy hole ...
    what's the dif as long as the trim covers it.
    don't see any cracks so far.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. FastEddie | Jan 05, 2009 05:59am | #5
      what's the dif
      Pride in your workmanship vs banging it out as fast as possible."Put your creed in your deed."   Emerson
  3. calvin | Jan 05, 2009 05:42am | #3
    That there is a slightly different install procedure.
    http://www.quittintime.com/
    SteveInCleveland | Jan 05, 2009 05:44am | #4
    Drill small hole.
    Insert M-80.
    Light wick.
    Install shower valve.
    "Preach the Gospel at all times; if necessary, use words."  - St. Francis of Assisi
Premium Pipe Reamer
This tool reams 1-1/2-in. fittings in schedule 40 PVC, CPVC, and ABS.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
