Power vent water heater noise level
timc | Posted in General Discussion on April 1, 2012 03:14am
We have a power vent water heater that cycles on and off throughout the night. The noise is not a problem during the day but I would like to eliminate it as much as possible at night. Is it possible or advisable to install a timer so that the fan will only come on at certain times? Does the thermostat reset to the lowest level when the unit is turned off and then back on (e.g. after a power outage does it need to be reset?)
  1. DanH | Apr 01, 2012 03:22pm | #1
    Easy way to test if it needs to be reset after a power failure:  Trip the breaker.
  2. semar | Apr 02, 2012 11:40pm | #2
    waterheater noise
    Have the same problem
    Heater installed in a utility room beside MBR
    Thermostat set on 125 F, cycles thru-out the night. But cycles only 2 or 3 times for about 5 min.
    Model AO Smith Effex 40 gal
    Talked with AO Smith trying to cover any angles. No result..
    Other problem is the humming transformer.  They claim it is normal.
    Like Dan said you get used to the noise to the point where you don't register anymore.
    Could probably spend money to soundproof the utility room.   Is it worth?
  3. IdahoDon | Apr 03, 2012 11:38pm | #3
    I'd spend my time soundproofing the utility room - perhaps start with an insualtion blanket that can be wrapped around your entire heater.
    1. semar | Apr 04, 2012 11:48pm | #4
      noisy hw heater
      If he has the same type a I have (AO Smith) wrapping the tank will not work since the powerfan is attached to the tank and has slits to suck in surrounding air.
      Soundproofing the utility room is a better solution. Just don't make it airtight. The bad side is if there is an opening somewhere in the room (door-undercut) sound will travel; you will not get it 100% but it will improve it
      1. IdahoDon | Apr 05, 2012 12:13am | #5
        Air must be allowed to enter the fan, but I don't see anything wrong with wrapping the tank as long as room is left for air to enter to the fan.
    BossHog | Apr 06, 2012 06:50am | #6
    I don't think a timer would hurt it. It's not like there are sensitive electronics in the thing - It's just a thermostat and fan.
    Why not give it a try and see what happens?  And come back to let us know?
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
