In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Preventing frozen water lines.
Jeff Pintler | Posted in General Discussion on August 25, 2009 04:01am
This weekend I am running a new water line to the barn.  The water line exits the pump room about 12″ above the slab, through the basement concrete wall to a three foot wide passage 20 feet along a 8 foot high retaining wall.  I can not excavate the footing of the retaing wall down 24 inches to the frost line.  Do I use pipe insulation protected by 4 inch pvc pipe?  Do I use heavy wall copper pipe and heat tape (that can fail)?  I plan on using black poly 160 psi and a bed of sand for the line that can be buried down 24 inches.  I did search the achives.
Thanks guys in advance.
  1. level | Aug 25, 2009 05:49am | #1
    Put some rigid foam(couple of inches) over the top extending the width of the trench if narrow or 16 inches or what ever you have, then back fill. Sleeve the pipe as well so you can water jet it with hot water if it freezes.
    Don't shovel the snow when it falls as the snow will help it the cold snaps from freezing deep.
    good luck
    rob
      SamT | Aug 25, 2009 04:31pm | #3
      An inch of foam is roughly equivelant to a foot of soil. Its protective zone tapers at about a 45* angle inwards, like an upside down pyramid. The point of the pyramid must extend below the true frost line to give any protection to a pipe, but it's best to have half the pyramid below it.
      Since the OP 's frostline is 24" below his waterline, IMO, he should use at a minimum, a full 4' wide, 2" thick foam right above it.  Personally, I would use 2 1/2" foam and put 1" pieces on each side before placing the sand bed.SamTA Pragmatic Classical Liberal, aka Libertarian.
      I'm always right! Except when I'm not.
    Dinosaur | Aug 25, 2009 07:41am | #2
    Generally, when we can't keep a water hose below the frost line throughout its entire run, we place a specially made heating cable right inside the hose itself. This is very common with water supply lines coming from lakes. Most rural plumbers in cold climates will carry this type of cable and the thermostatic control units to drive them. Pyrotenax is one brand.
    A cable less than 60 feet long will usually run on 120vac; anything longer than that will require 240v. These 'hot wires' are moderately expensive; a 160-foot wire with control box will run between $750 and a thou.
    Dinosaur
    foolish men call Justice....
Durable Wide-Plank Floors Made From Hickory
The Earthen collection from Carlisle Wide Plank Floors combines a unique look with the advantages of an enduring material.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
