FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Propane or electric forced air????
BUILDER | Posted in Energy, Heating & Insulation on August 11, 2004 05:56am
I am a home owner adding a 1,100 sq. ft. addition onto an existing 1,300 sq. ft ranch.  I live in central Ohio and am going to upgrade the old electric forced air furnace and heat pump.  I am trying to decide which route to go, propane of electric forced air.  Which will be more efficient to operate?  New heat pump will be a 13 seer rated.  I also use a wood stove part of the time.  Thanks for any info.
  1. junkhound | Aug 11, 2004 07:35am | #1
    Gotta factor in your rates and weather patterns. As an example, here are a couple of installations studied recently,  one for Kent WA and another for Spfld, IL.  SPFLD probably near your weather pattern, but your elec rates are probably much higher.  Factor the differences for your answer.
    RichColumbus | Aug 11, 2004 08:11am | #2
    I am currently in the same situataion.... 1800 sq ft addition on an existing 1500 sqft house.  Columbus, OH
    I had a mechanical engineer look at it, and he suggested two units for the house.  I am running nat gas... so no comparison on types.  But you may want to look at whether the efficiency is dramatically effected by long runs of duct, etc. in your layout.
  3. JohnT8 | Aug 19, 2004 08:07pm | #3
    A geothermal (aka 'ground source') heat pump might meet your needs.  They are far superior to regular heat pumps (air source), especially in cold climates.  The geothermal heat pump is probably the highest efficiency unit available, but it also costs more than most other units.  Whereas the regular heat pump draws heat out of the air, a geothermal heat pump circulates fluid through several hundred feet of buried tubing.  It extracts the heat from the earth rather than the air.
    The geothermal can be used for both heating and cooling.  The unit is electric and since there is no combustion, there is no venting necessary.  The unit is quiet and fully contained within the home.
    The additional cost of a geothermal heat pump is due largely to the buried tubing.  There are two typical loop layouts:  Horizonal (where a trencher is used to bury the tubing), or Vertical (where well drilling equipment is used).  Fine Homebuilding has done a couple articles on geothermal, but I don't know the specific issues.
    You might also check with your local utilities to see if they offer rebates.  If your climate is cold in the winter and hot in the summer... and your electric rates are not excessive, then the geothermal might be a good option.
Exterior Materials for a Midcentury Home
Travis talks with the architect about his thought process for choosing the materials that create a functional and seamless aesthetic for this house.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
