What are the pros/cons of installing kitchen cabinet bases and islands first, then installing tile? Any special considerations for appliances such as the fridge?
It is easier to install cabinets over a fully finished floor. the other advantage is appliances that fit under the counter are going to fit. You can also hide seams & bad cuts under the cabinets. The down side is it needs to be a durable floor covering like ceeramic tile. Vinyl requires careful movement to avoid damaging it.
*I prefer to put my cabinets over a finished floor. I can make the tiler look good, doesn't work out so well the other way, plus they can do a lot of damage to cabs. Rob is right about the appliances too. as far as I'm concerned, the cabs go in last except for the final coat of paint.
*Eric,
Joseph FuscoView Image
*I prefer installing after the flooring is down, also.b Pro: Tile, hardwood, etc. goesb TONSfaster. no teeny little slivers, no grout joints up against your toekicks--just a nice bead of caulk against them. No worries about appliance height, etc. b Cons:b Watch out on your full-height cabinets!If you've got a 96" pantry and an 8' ceiling height, you may be in for a bit of creative cabinet modification.
