Radiant heat piping options
I am installing a wood floor in my shop – 26’x32′. Is there an alternative to the commercial plastic tubing? I have a wood fired boiler (exterior location) toprovide the hot water.
These plywood clips allow you to strengthen the walls around pocket doors to support shelves, cabinets, and other fixtures.
Jeff, you could go with copper as long it doesn't come in contact with steel. Why not PEX? I'm assuming that's what you mean by "commercial plastic". Is the wood floor going over concrete? Have you considered a radiant ceiling? I have it in my house and it works very well. I'm currently doing an addition that will have extruded aluminum plates with PEX tubing over a sleeper system then drywall over that for the finished ceiling. Since the wood will act as an insulator and the temp should not exceed approx 82 degrees (because of wood floor) you'll need to make sure that you can get the BTU's out of the floor to heat the shop.-Ed
Thank-you for the input. My least complicated option is to hang a "radiator" on the ceiling and run a fan. I may be doing just that.
