If you wanted to build a heating system using radiators and in-floor tubing wouldnt diathermic oil be a better & more efficient choice than water & antifreeze. Also you could use cheaper (non oxygen barrier) PEX .
JMHO, Roger
Find online articles on A Fine Finish for Wood Exteriors; Furnace to Heat Pump Retrofit; Windows Before Housewrap?; More Building Science Mistakes to Avoid; EV Chargers and much more.
JMHO, Roger
