Radon mitigation vent
SamR | Posted in Energy, Heating & Insulation on February 12, 2007 12:31pm
New house in Wyoming–everybody has radon here.  I put radiant heat in the basement slab and should pick up any radon gases in the 3/4″ stone under the floor with a 3″DVW PVC pipe thru a partition wall to the attic space.  I have not gone thru the roof with the 3″ pipe yet.  Question–Does anybody know why connecting this pipe to a plumbing vent with a Y would not be a good idea?  One less roof penetration is my thought.
  1. AhneedHelp | Feb 13, 2007 06:55pm | #1
    If I am not mistaken radon venting works by 'sucking' air out of the below-slab area such as yours, creating negative pressure so the gas doesn't infiltrate above slab and into living area.
    This typically involves an inline exhaust fan of some sort.
    The plumbing vent stack - which is usually passive - may actually draw the exhausting radon back into the house when the drains are active?
    Around in the east coast most of the radon venting come out the wall and travels up on the exterior, but these are mostly retrofits.
    I do understand your desire to minimize roof penetrations.
    Edited 2/13/2007 11:01 am ET by AhneedHelp
    1. SamR | Feb 13, 2007 11:13pm | #2
      I hadn't planned on putting a fan in the radon stack unless test readings indicated a need for the positive venting.  I was just going to give the underslab pressure,  if there was any, a place to go
      If a fan turned out to be necessary, I could disconnect from the plumbing vent and then put the extra hole in the roof.
      1. AhneedHelp | Feb 14, 2007 12:12am | #3
        This is just a guess on my part, but with all the paranoia and the litigious society we live in, active venting is probably the code requirement if this is an inspected job.Not sure how it would work if it is a voluntary installation.
        A radon mitigation contractor - licensed presumably - would probably recommend or insist on an active (fan assisted) venting scheme.Only to tell would be to do a test before and after with whichever method you choose.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
