Rain screen, solo siding question
andyb | Posted in Construction Techniques on March 12, 2008 02:43am
Need to start siding my own home this spring.  Upstate NY location, tall 3 story.  Planning on using Hardy clapboards.
I’d like to get some opinions about using rain screen detail.  Basically is it worth the extra time and effort?  One man crew here with a lot to get accomplished this spring and summer.  No problem spending the time if it’s worth it.
Also wondering about devices used to temporarily suspend and space the far end of a piece of siding while installing.  Basically they allow solo installation.  It seems like they maintain an even exposure on the courses.  Confused as to how these things allow some variation between course exposure to line up with tops of window and door trim?
Thanks for any help.
  1. edwardh1 | Mar 12, 2008 04:46pm | #1
    Hardie lap siding is great stuff but a helper to just hold the other end would help you- its floppy- good summer job for a kid?
  2. RippySkippy | Mar 12, 2008 04:58pm | #2
    WRT the holding siding...I got a pair of the SoloSiders and I found them very easy to use and have the adjustability you mention.  This link is to Amazon, and I notice of the 11 reviews all gave 5 Stars.  In situation, they are more reliable than my access to a second pair of hands.
    1. andyb | Mar 12, 2008 06:18pm | #4
      That's exactly what I need.  Thanks a lot.
  3. FHB Editor
    JFink | Mar 12, 2008 05:03pm | #3
    If it were me, I wouldn't consider doing it any other way than Rainscreen. It just makes too much sense to ignore, and you will sleep so well at night knowing you did it.
    As for siding gauges that allow you to adjust the exposure, I agree with the above - I think the solosider is probably the best bet for that situation.
    Justin Fink - FHB Editorial
      JeffBuck | Mar 13, 2008 01:41am | #6
      haven't used the solo sider ...
      have used a coupla other similar ones that also hang from the top of the last row.
      can be a pain in the #### to remove them quickly and move on.
      best out there are the gecko gauges.
      most expensive ... worth it.
      they slip off and one easily with one hand.
           Buck Construction
       Artistry In Carpentry
           Pittsburgh Pa
  4. akjack | Mar 12, 2008 08:18pm | #5
    I have to agree with the Ripster- Have a pair of SoloSiders and they are a pip! Did mucho research prior to purchase and found them to be the only adjustable ones out there at the time. Go to their site and watch the video which shows the adjustment in action. Like the man in the video says, if the winds a blowin', be prudent. Also on their site they have some printable "tables" per exposure in case you need to calculate some fudge factors to make things even out- a bit of a time saver.
  5. Riversong | Mar 13, 2008 02:56am | #7
    First, I have to say that rainscreen is over-rated and over-used.  If you have a good air/vapor barrier so that there is little to no moisture migration from inside to out, and you do a proper job of exterior flashing and detailing, simply using a good drainage plane membrane (such as 15# felt) and backpriming and end-sealing the siding, you shouldn't have any problems with longevity of either siding or finish.
    Hardiboard, in particular, does not require a rainscreen the way white cedar sidewall shingles might, to prevent cupping.
    As far as solo siding with lap siding, I do this all the time.  You can purchase a device like the Solo Sider, or you can make simple jigs and modify for different exposures if necessary.  Here is one I use often:
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    Edited 3/12/2008 7:58 pm ET by Riversong
    1. frammer52 | Mar 13, 2008 03:12am | #8
      I like that.
      You are echoing my fealings  about "rain screen"
      Personally when I side alone, I have chalk lines, gun in one hand knee and the other hand and manage quite well.  Of course this is when using hardiplank
      Cedar is so lite, it is very easy to side solo
    2. fingersandtoes | Mar 13, 2008 08:11am | #9
      I have mixed feelings about rainscreens too. Unfortunately here it is the law for all new residential buildings. It was brought in as a reaction to envelope failures due to poor building practices in BC. Now we are all stuck with it.
      The rational I have heard for using it with Hardiplank is that well installed Hardi acts as an exterior vapour barrier and does not allow the wall to vent to the outside.
      As an aside... Any thoughts on my wine storage insulation problem in the Energy and Insulation Forum?
      1. Riversong | Mar 13, 2008 09:25pm | #10
        I just looked up the perm rating of Hardiboard and it's just a hair over 1 for 7/16" thickness, pretty darn close to a vapor barrier.
        That's yet one more reason for me to avoid using it.  Besides having to protect your lungs from the silica dust (unless you're using a guillotine cutter), my thumb rule is to keep the outer skin of the wall at least 5x as permeable as the inside skin.  No rain screen is needed in that case, as long as outside detailing is appropriate to prevent rain infiltration and a latex-based (permeable) exterior finish is used.
        Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
  6. cliffy | Mar 14, 2008 06:29am | #11
    Check into a new product I think called "slicker".  it is tyvek or typar with a drainage, ventilation plane built in and in house wrap size.  Saw a sample at a trade show a little while back.
    Have a good day
    Cliffy
  7. Waters | Mar 14, 2008 07:11am | #12
    Watch this:
    http://www.pactool.us/demo/sa903.htm
    "Research is what I'm doing when I don't know what I'm doing..."
Flashing a Window Using ZIP Tape
Travis and Joe walk through the step-by-step process of prepping, caulking, and flashing a window using stretch tape and flashing tape from ZIP System.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
