I’m involved in a project wnere the toilet will have to be raised about 4″ to drain. The owner does not want to raise the floor and says the assisted toilets are too loud, and I can’t cut the joists. Anyone know of a low bowl or a wall mounted toilet, or any other solution?
The FHB Podcast crew offers expert advice on choosing the right insulation for the roof of a small, balloon-framed home.
I think a company called Toto makes a wall-mounted toilet that may work for you.
*How about a raised "floor" that is only slightly larger than the stool? Great if your customer is tall.What's underneath? Can the waste line be re routed?
I'm involved in a project wnere the toilet will have to be raised about 4" to drain. The owner does not want to raise the floor and says the assisted toilets are too loud, and I can't cut the joists. Anyone know of a low bowl or a wall mounted toilet, or any other solution?
