Remove paint from SS stove pipe
netanyahu | Posted in General Discussion on October 13, 2008 03:18am
I removed some SS metalbestos stove pipe from a house and want to re-use it on my house.  One side of the pipe has some red paint overspray on it, fairly heavy in some places.  What can I use to remove it?
  1. Ozlander | Oct 13, 2008 03:54am | #1
    Paint Remover? Acetone? Lacquer Thinner?
    kurt99 | Oct 13, 2008 04:02am | #2
    If this is spray as in spray can paint, most of it is acrylic and can be removed reasonably easily with Goof-Off. Some like Rustoleum are oil based and will need a real paint stripper. Similarly, if someone dumped paint into their spray gun, Goof-off will work for latex paint but not oil.
    1. netanyahu | Oct 13, 2008 04:19am | #3
      it is not from a can.  it just looks like someone wasn't very careful with a spray gun.  dont know if it is latex or oil paint
        kurt99 | Oct 13, 2008 04:28am | #4
        I would start with the Goof-Off. If it comes off, it is latex, if not, it is oil and then proceed with a full fledged paint stripper. Goof=Off is handy to have around the house any ways to remove latex paint splatters, magic mark and adhesive residue.
          BarryE | Oct 13, 2008 04:40pm | #9
          Goof-off is xylene in expensive packaging.Save yourself some money and buy the xylol
          Barry E-Remodeler
  3. IdahoDon | Oct 13, 2008 05:39am | #5
    The citrus paint strippers will work on oil or latex and aren't overly toxic.
    shelternerd | Oct 13, 2008 05:42am | #6
    Latex paint releases well to denatured alcohol. It'll reach through an oil poly finish and pull pencil marks off wood below with out trashing the finish as well.
    1. BillBrennen | Oct 13, 2008 08:33am | #7
      Really? I'll have to try that someday. Amazing the stuff I learn here. That was oil-based polyurethane varnish? I always thought it was pretty impermeable, but gotta do the test now.Thanks for that tip.Bill
  5. junkhound | Oct 13, 2008 01:36pm | #8
    methyl chloride
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
  • Insulation Scrap Dispenser
