I have an old house that has 1970’s panelling applied over fir bead board. The panelling was applied with construction adhesive and I have been able to remove the panelling without damaging the bead board. The only problem is that the construction adhesive is still on the bead board and I need to remove this so I can paint the bead board. Is there any particular solvent that I should use to remove the construction adhesive. Thanks, Mark.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
I have an old house that has 1970's panelling applied over fir bead board. The panelling was applied with construction adhesive and I have been able to remove the panelling without damaging the bead board. The only problem is that the construction adhesive is still on the bead board and I need to remove this so I can paint the bead board. Is there any particular solvent that I should use to remove the construction adhesive. Thanks, Mark.
