Hi,
I posted this message on the Breaktime forum but thought the general discussion forum may also be worthwhile. Just in case there are other Marks in this forum, I am new to this message board and forum and am hoping someone (or many of you) can give me some help with a somewhat overwhelming situation I am currently facing. I apologize in advance for this very long-winded message, but I have a long list of issues and circumstances are pushing me to try and get as much information as possible in a short period of time. I am a homeowner in the Mid-Atlantic (Washington, DC area) and am in the process of deciding on how to have my roof/gutters/downspouts/aluminum siding replaced and by whom. My house was the victim of a hail storm and now contractors chasing the storm have descended on my neighborhood with offers to do all the work and more at good prices. However, each contractor (as well as outside contractors that I have talked to) say something different about what “needs” to be done and what “should” be used to do it. Generally, I have accepted that this is a good opportunity to have some additional items done to my house as upgrades and improvement. But, my problem is how to educate myself on what is best and what is a waste of time and money. I have accepted that vinyl siding is probably the best choice under the circumstances for a reduced maintenance exterior and am considering having the rake boards, fascia, windows, door ways, and soffits wrapped as well with the addition of 1) a layer of insulation board added between the vinyl siding and the exterior walls, 2) a 3D roof upgrade in place of a standard 25 year roof, and 3) a ridge vent added where none was before (we currently have end vents with an attic fan to vent the attic space). So, I have a number of questions that I hope people can shed some light on so that I do not do something I shouldn’t to my house.
Issue One:
Siding. Who makes the best siding and what grade should I use? A number of contractors recommended Alcoa Liberty Elite (.048″ thickness) over other names. Is .048″ that much better than .046″ or .044″, or .042″?
Issue Two:
Insulation. One contractor told me that I need something between the sheathing and the new vinyl so that the vinyl will not deteriorate at the nail points from the friction caused when the vinyl expands and contracts and rubs against the sheathing. He recommended the insulation as a good barrier for this purpose with the added benefit of creating a relatively flat surface for the vinyl and adding insulation R value to the house. He also recommended Amocor P38 (3/8″) insulation board for this. Another contractor told me that the increased insulation value would be marginal in the grand scheme of things, but the sound dampening effect would be worth it, this contractor also told me that if we did not want the insulation board he would just hang the vinyl siding right on the existing sheathing. Other contractors just demonstrated a 1/4″ insulation board (P14 rating) and said that should do. What is the best choice and do I need something between the sheathing and the vinyl siding at all? Will not putting anything between the vinyl siding and sheathing cause the siding to deteriorate before its time or cause other problems?
Issue Three:
Sealants. One contractor told me that OSI Quad rubber sealant is the best and the only sealant he will use for the job. It this the best? Can anyone recommend a comparable products and should I really be concerned with this?
Issue Four:
Ridge venting. Should I add ridge venting? My home currently does not have ridge venting. The existing venting is through vents at the ends of the attic spaces and thermostat controlled attic fans. One contractor told me that he would put ridge venting in since it should improve the venting of hot air. Another contractor told me that it wouldn’t do much good since my house does not have intake vents in the soffits so the ridge venting would not do more than look good on the roof. Still another contractor told me that I would need to add soffit vents as well as a type of insert in the attic along the roof sheathing to maintain an open flow of air from the soffit vents to the ridge vents. Yet another contractor told me that the passive venting of a ridge vent system would not even work as well as the active venting of my attic fans and I would need to close off the louver vents at the ends of the attic to get the full advantage of any ridge vent system. After all this input, I do not know what to do about adding ridge vents.
And if I do want ridge venting, what is the best or recommended type? I have been told that I should use an aluminum ridge vent since it will maintain a straight edge on the roof ridge over time while a plastic material will warp or contort over time due to exposure and heat. Given all the hail storm repairs and replacements of roofs in the neighborhood, I spoke with some neighbors and some are getting straight plastic ridge vents (about 3 ft sections) while others are getting a material that is rolled out as a ridge vent (they showed me a box that said Lomanco Omniroll OR-20). None of the neighbors really seemed to care what it was made of. Does it really matter?
Issue Five:
Gutters and downspouts. I have been trying to get a clear picture of what is worth my money. Since I am considering strongly using the Alcoa siding I looked at the Alcoa web site and saw that the thickness of the aluminum material various. Since I live in the Washington, DC area and do not consider my area to be an exceptionally wet area as far as rain is concerned, does it matter that much if my gutters are .032″ nominal thickness or .027″ good enough?
Issue Six:
Roof. I have already concluded that a replacement roof is probably warranted since mine is already 15 years old and it was rated as a 20 year roof (builder’s grade). The recommended replacement roof by most of the contractors is a 25 year three tab fiberglass roofing shingle made by CertainTeed. I am considering whether or not I should have a new roof put on top of the old roof or get the old one removed first. The existing roof doesn’t seem to have any problems now and it is the only roof on the house. Does it make a difference if I put the new roof on the old one?
I am also considering an upgrade to a 3D (or some call it an architectural shingle). Does this impact upon any consideration as to putting a new roof over the old roof? As for materials, a number of contractors are using 3D roofs made by GAF, but one contractor said Owens Corning is just as good and I should choose based on the look I like. Another contractor showed me 3D from CertainTeed as well — all three are 30 year rated. Is their any difference in quality or are they all basically the same? Does anyone have any opinions on whether or not 3D roofs are worth the investment or not? I am somewhat on the fence on 3D roof since I look at it as adding 5 years to the roof (maybe?) and curb appeal, but the cost seems somewhat steep – I have been quoted anywhere from $750 to $1,200 depending on the total other items I will have the contractors do at the same time. The totals for the entire project are somewhat in line if I add all items I have been discussing with the contractors. Its how they get to the total that is different. Funny how that happens.
Issue Seven:
Trim wrapping. I am considering adding the trim wrapping to the project (fascia, soffit, rake board, and window/door trim). Does it make sense to wrap all these items or are some more important than others? I will probably have to have any wood trim painted in the next year or two since I am noticing some pealing of paint in weather exposed areas already. Also, I have been told that the fascia, rake boards, window/door trim are wrapped in aluminum while the soffit is done in vinyl (with soffit vent inserts where needed). Is this true and does it make a difference?
In summery, given the above I hope you understand how confused I am with all this. I didn’t anticipate this project anytime in the near future so this is a lot for me to absorb at once. I hope anyone reading this posting will appreciate my situation and give me a little advice on what they would recommend even if its only with one of my issues. I am hoping to balance cost while not necessarily sacrificing quality and in the end not doing anything that would cause more bad than good. I am also hoping that out of the above information I have received from contractors wanting to do the job, I will be able to determine which one will do the best job. Anyway, thanks in advance for any advice anyone can give. Thanks.
