replacement windowa
adam22 | Posted in General Discussion on October 10, 2006 12:08pm
Im looking to put in new replacement windows and have a simple question for most of you on breaktime. If the windows were put in from the outside, would all the windows have exterior stops? Im trying to do research and they all say to take interior stops out and put replacement window against exterior stop. Thanks for all the replies in advance.
  1. Piffin | Oct 10, 2006 01:00am | #1
    I am trying to think of a situation where you would not have exterior stops.
    What kind of windows do you now have?
    1. Shep | Oct 10, 2006 02:59am | #3
      I've done a couple of jobs installing replacements in casement frames. They generally don't have exterior stops.
      I'm not crazy about replacement windows, but sometimes ya gotta take jobs so you can pay the bills.
      1. Piffin | Oct 11, 2006 12:16am | #4
        Yeah, I have one to figure out for a guy who has given me 500K of work on a cottage he has. I really don't want this one...It happens to be french casements that we need to replace, and the wall is thin - only a 3-1/2" jamb at most. Marvin thinks they can probably put a wood DH into an AL clad frame/jamb for me. The wood frame/jamb is full 4-9/16"
    2. adam22 | Oct 11, 2006 12:31am | #5
      My windows are single  paned,original to the house. They have aluminum tracks that fit into aa dado routed in the window. The reason I am asking this question is if windows are put in from outside,and secured from outside,why do you need exterior stops. I lokked and did not see them. Thanks for all the replies,this has helped me out alot with this info
      1. Shep | Oct 12, 2006 01:08am | #6
        part of the reason for the exterior stops is to keep any wind-driven rain from getting into your house, around the edges of the windows.
        How about setting the windows from the outside, and then installing some exterior stops, preferably in some caulk to seal everything up tight.
  2. Shep | Oct 10, 2006 02:55am | #2
    If your windows don't have exterior stops, you can glue and nail stops on to give you someplace to set the window to. I usually add a 3/4" x 3/4" stop, but 1/2" x 3/4" is OK.
  3. shellbuilder | Oct 12, 2006 02:38am | #7
    Most guys who install vinyl windows to replace wood sashes and remove the exterior stop. They bend  the metal wrap over  the removed areas of stop and back in another inch or so  and bend the sill piece to under the bew window and set the window in between the metal.  Better method with this is to sawzallout a slot in the side jamb above sill and have the sill piece slide under the jambs.
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
