In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Retrofitting exterior sheathing or vapor
Clyde | Posted in Energy, Heating & Insulation on October 16, 2005 09:30am
I am in the process of renovating an older home in the southeast that never had insulation in the exterior wall.  We have taken everything down to the studs, and now have exterior lapboard directly on the 2 x 4 studs with no exterior sheathing or vapor barrier between the studs and exterior cladding.  Short of removing and replacing all of the lapboards (which is not economically feasible), how can I best provide an after-the-fact vapor barrier?  Building codes normally require that wall insulation be installed with the paper side to the interior of the house.  I’d thought of trying to get the inspector to let me do the opposite and then attach an extra vapor barrier to the inside walls prior to hanging sheetrock.  Any other ideas?
  1. experienced | Oct 16, 2005 10:47pm | #1
    In the southeast, you really don't need a vapour barrier but an air barrier that is permeable to vapour flow. Since you may have air conditioning that makes the inside wall board the cool surface in the summer, it may be the surface that condensation occurs on. A vapour barrier just behind the interior wall board would not allow the condensed moisture to dry to the inside by diffusion.
    The best place to have the air barrier is on the exterior under the siding. The reason fdor this is to stop moisture laden summer from entering the wall cavities where it may condense on the back of interior wall board. You don't need a vapour barrier on the exterior. There are 2 ways (other than rain/water leakage) that moisture gets into walls: (1) water vapour in air leakage and (2) vapour diffusion through permeable materials. In your area, the air leakage will most likely constitute 95-98%+ of the moisture movement into the wall cavity so if you stop the air leakage , you stop the most important part of the potential problem.
    Also by stopping uncontrolled air leakage, you will reduce your cooling bills and increase comfort levels. It make no sense to pay to cool/dehumidify the air and then lose it through a loose building exterior shell. The air leakage may be responsible for from 20-40% of your cooling bill!!
    1. Clyde | Oct 17, 2005 01:00pm | #2
      Okay, so how would you go about this?  What air barrier would you install?  Would fiberglass insullation be sufficient?  Should it have a paper coating on one side or not?
      1. experienced | Oct 17, 2005 02:37pm | #3
        The best way would be the economically "not feasible" way- remove the clapboards and install an airsealed permeable building sheathing membrane/housewrap such as Tyvek/Typar or similar. This would give you the best chance to get an airtight exterior wall that wlll not allow leakage of air with high relative humidity into the cavity.
        Barring total removal of the exterior boards, the next best approach would be to cut, fit, attach and seal the membrane in between the open studs and wall plates at their exterior edges where the boards are attached. All wiring and other service penetrations through the membrane should be sealed by using red sheathing tape, foam or non-hardening caulking. Where the main house walls rest on the foundation, it may be possible to remove the bottom 2 or 3 exterior boards and seal here with membrane, tape, foam or caulking.
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
