rigid foam insulation/roof application
vaughan | Posted in Construction Techniques on February 25, 2007 01:53am
I am beginning a new house project and the ceiling application will be open/exposed rafters with cardecking sheathing over the top.With this detail I will need to place 1/2 inch ply down on cardecking (as per engineer) then it calls for rigid foam R-30 with 2×6  rafters standing inbetween at 24 inch oc., this all covered with 1/2 inch ply.I understand all this but my questions are air ventilation and vapor barriers.My location is Pacific NW if that has any bearing. Also my mind has thought about just having insul panels made up and placed on top of my” first roof”, I would think it is much easier but at what expense vs hand building of the “second roof.”Appreciate any feedback or experiences on this matter.    joe
  1. rez | Feb 25, 2007 08:29pm | #1
    Greetings vaughan,
    As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
  2. Piffin | Feb 25, 2007 08:58pm | #2
    You are right. SIPs is the way to go there.
    You would not even be able to fit enough EPS foam in that 5,25" space to get R-30 insulation.
    5.2R X 5.5" = 28.6 at best.
  3. atrident | Feb 25, 2007 09:42pm | #3
      Premier makes SIPs in Kent Wa. Google them and check with a planner.
  4. karp | Feb 26, 2007 07:29pm | #4
    Recently had this same problem, solution, ( worked out between roofer, building inspector and architect ) 1 layer of torch down roofing on top of ply. acts as vapour barrior, 5" poly-iso rigid insulation, (approx. r30) fibre glass mat, (fire protection.) 2 layers torch down ( 1 base 1 cap ) to finish. No venting required. Solid construction, no voids, no free air. Have heard it called "upside down roof" or "sandwich roof"
    1. vaughan | Mar 02, 2007 05:21am | #5
      Thanks for that insight,so how do you place a fachia board on the face of the "inso sandwich".I cant see where the nailing of the fachia board would have backing?Must be some detail to cover this.   jv
      1. karp | Mar 02, 2007 06:19pm | #6
        On our project, we had a parapet wall, so the "sandwich" died into it with a scupper detail for drainage. This created another problem where the wall insulation below met the roof. The inside of the parapet was not insulated, leaving only about 2" of coverage between the roof and the wall insulation. Hard to explain, but sketch a section and you get the idea. This was solved by spray foam in the roof joist bays at the perimeter and extending it far enough to capture the iso on top. If a parapet dosen't work for you, run a 2x6 on edge around the perimeter and cap it with torch down, metal flash to finish.
      2. paul42 | Mar 02, 2007 08:05pm | #7
        Rip a 2x to the thickness of the foam.  dig out the foam 1-1/2" and replace the removed foam with the ripped 2x  nail the 2 x in place and use it for the backer for your fachia.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
