Rim Joist Sealing
Kimball_house | Posted in Energy, Heating & Insulation on November 22, 2008 05:22am
I have a hundred year old house.  I am in the midst of sealing the interior of the rim joist area with sealant, foam board and expanding foam.  There are some regions where there is a lot of air infiltration, and I believe one cause is gaps between the exterior siding and the mudsill.
See photos.  What would you folks do to seal the outside in this space?  Caulk?  It is pretty cold now so I may have to wait on this step so the caulk or sealant will set.  Specific reccomendations for products appreciated!
  1. Piffin | Nov 22, 2008 05:50pm | #1
    Don't try top seal the whole edge there, just squirt some foam in where the big holes like in third photo show.
    if you try to seal that horizontal sea, totally , then any water that gets behind the siding on the whole wall can be trapped and re-diverted to run in instead of down.
    You are dealing with most of the infiltration problem from the inside.
  2. Clewless1 | Nov 22, 2008 06:20pm | #2
    Not sure what the two pics are ... from underneath looking straight up? What is the large gouge we see in the one pic? A chunk of mudsill missing?
    Generally, though I would tend to say ... don't seal it ... you are providing air sealing on the inside. You don't want to create a condition that might trap water in some fashion. The only place you might consider sealing would be the actual joint of the mudsill w/ the foundation (did I see a foam mud sill sealant in the pic?).
    Based on your description of your work on the inside ... your work should be largely complete. Unless you have other specific issues, I wouldn't put a lot more effort into it.
    One thought might be to run a piece of flashing up under the siding and then seal/secure it to the mud sill if you are having bulk water issues.
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
