ROMEX DISPENSERS – home made
toolbear | Posted in Energy, Heating & Insulation on April 17, 2007 06:40am
I am looking at the Greenlee folding stud mount caddy cable dispenser for a mere $120.  I don’t think so.
I am looking at my home made plywood and 2×4 dispenses for $10.  Cheaper, but the design still has flaws.
Need some sort of swiveling dispenser eye.  Cable wants to fall off the the plywood round.  Used scrap wood and pipe for a reel stand.  The pipe rotates on the bottom of the eye bolt used to hang the reel.  Rotates nicely.  Cable control needed.
Looking for other home made dispenser that work – cable reels off but doesn’t fall off.
The ToolBear
“Never met a man who couldn’t teach me something.” Anon.
  1. davidmeiland | Apr 17, 2007 07:18am | #1
    There was a thread about this 6 months ago. A lot of guys use an orange utility cone hanging from the ceiling or from an interior door header.
    1. toolbear | Apr 18, 2007 04:25am | #5
       Idea!  I can do that.  Have to give it a try.The ToolBear
      "Never met a man who couldn't teach me something." Anon.
      1. ponytl | Apr 18, 2007 05:28am | #7
        i make em for my sparky in 5 min... use'n a utility cone... i bend a 1/4" rod  in a  upside down U then bend each led out 90degrees  about 2-3 inches out... on each leg... drill 1/4" hole thru cone about 2-3" down from top  in one side out the other...  this is where the bent out legs of your U will go...
        home depot  cheap snap swivel is what you'll hang it from...  i made him some brackets that are C shaped that hang on a 2x stud where the weight hold them in place... has a 14" arm with a hook on the end to hang your cone from...  we use them for MC cable  but ...
        good luck
        p
    BillHartmann | Apr 17, 2007 07:22am | #2
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=83197.1
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=41985.1
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=42097.1&search=y
    Edited 4/17/2007 12:25 am by BillHartmann
    1. toolbear | Apr 18, 2007 04:37am | #6
      Bill -
      Thanks for finding the thread messages on romex dispensers.  I notice a contribution from the ToolBear there. <g>  That was the old Xmas Tree pattern.  I have moved upmarket to cheap plywood knockoffs of the Greenlee.
      Downloaded their catalog picture and blew it up.  They have a rotating eye or fairlead.  We need an eye that will keep the cable in the plane of the coil.  Once it leaves the eye, pull in any direction.
      Knocked one up of furring today.  Worked fairly well.  Next - one of PVC for the smooth edges.
       The ToolBear
    xxPaulCPxx | Apr 17, 2007 09:31am | #3
    I used a 4x4 center post then put a BC40 post connector at the top.  It has a 1/2" hole in the center, in there I bent a 3/8" piece of steel to hang from - the bottom is just bent 90 degrees.  Not enough space between the 4x4 to angle itselfe out, but plenty to let it rotate freely.
    Also a CRX fanatic!
  4. Scott | Apr 17, 2007 05:42pm | #4
    I built a horizontal one: braced 2x4 posts at each end of a piece of ply, about three or four feet apart, and a piece of metal pipe through the middle of the posts. It held up to three different spools of wire.
    Scott.
    Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
