Roof and chimney flashing
Ribs | Posted in General Discussion on August 17, 2006 04:25am
So looking at what I hope isn’t too big a project. I’ve got a leak near my Chimney (12 inches of Rain in May in 3 days made me sure I need to fix it). Anyway Chimney is presently lead flashed, when I moved in it leaked on the back because there was no cricket and the water pooled. Plan is to reflash
Question is about the roof shingles. The leak has rotted out a few of the planks in the roof. I was planning on stripping off asphalt shingles in the area up to the peak. Removing the two/three bad planks and replacing them (framing looks sound). I was planning on using some of the same type boards I’ve saved from removal in another part of the house. The roof has two layers of shingles on it (It was like that when I bought the place). The rest of the roof is still fine, no leaks, no curling shingles and I can’t afford to have the whole thing done. So what do I do in this section? Do I put down two layers of shingles again to make it match the rest of the roof? I’d think I have to. I was planning on tackling this one this weekend. Anything else I should look out for. Anyway thanks in advance
Edited 8/17/2006 2:31 pm ET by Ribs
  1. jrnbj | Aug 18, 2006 07:24am | #1
    I'd be surprised if the "rot" was from the most recent rain....and your roof/chimney configuration doesn't normally get a cricket....I'd be looking real hard for some missing or deteriorated flashing (and true lead flashing should be still in good shape) detail causing the problem, & trying to fix that, before I'd try stripping a part of a two layer roof & trying to patch it back...think like water, & you may be able to find the leak, and a fix that gets you by until you really need to do the whole roof.
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
