Roof Rafter cutting pickle
rexwoodman | Posted in Construction Techniques on November 2, 2009 07:29am
I’ve got a problem.  I just found out I have limited access to the second of 2 skylight towers from inside a Cape Cod attic.  I need to cut a roof rafter (6″ actual joists) to gain access in order to insulate the far tower and do some bathroom ventilation work.  The roof rafters are on original roof section of house, and tie into a family room/bathroom addition roof that runs perpendicular.  The contractor who built this addition cut 2 original roof rafters and added a header in front of the first skylight, for a total spacing now of 48″ O.C.  However, I only have about a 10″w X 20″h access opening to the area that needs work….so I must find a way of gaining access, which i might as well try to make permanent.
My question is, how can I determine whether I can cut out one more roof rafter, for a total of 65″ spacing between rafters?  Obviously, I will need to build a new header.  I could also look at adding some vertical supports down to the attic floor (joists), but need some advice.  Sure wish the original contractor and inspector got this right.
Thanks.
Edited 11/3/2009 4:27 pm ET by Bill from Glenville
  1. mikeroop | Nov 02, 2009 03:33pm | #1
    My question for you  is how is 48" not enough ?
  2. frammer52 | Nov 02, 2009 05:37pm | #2
    Pictures with descriptions would help us understand your question.
    1. rexwoodman | Nov 04, 2009 12:15am | #4
      Okay, here are some pics that will help.
      1. 043b - overall view from rt. of skylight #1 and existing header with two roof rafters cut.
      2. 046 - Left side of skylight 'box'.  Roff rafter to be removed in view.  Existing header on upper rt.
      3. 048 - straight on view of framing
      4. 056 - limited access to crawl space above addition.  Size is too small for a person to crawl through.  I need to get in here to insulate area properly and work on bath fan ventilation.
      5. 057 - view slightly above access opening and potential roof rafter to be removed.  This view shows roof rafter angle in addition (combo bath and family room)
      6. 066 - here's the goal:  area above bath, around skylight #2 and family room walls that need insulation.
      Here's how not to frame a remodel.
      Thanks.
      Bill
      1. frammer52 | Nov 04, 2009 12:56am | #5
        Are you saying you want to remove a rafter to have access?
      2. frammer52 | Nov 04, 2009 12:58am | #6
        Where do you live?
        1. rexwoodman | Nov 04, 2009 02:55am | #7
          Yes, I'd like to remove about 4' of the roof rafter to the left of skylight #1.  I would box out to the next rafter to the left with a long header (65" or so) ...eliminating/replacing the existing 48" header.  I live in upstate NY.
          1. frammer52 | Nov 04, 2009 05:40am | #8
            I think you are going to be in a world of hurt if you do that.
            I would if at all possible access another way.  I would take the skylight shaft apart, before I cut another rafter.
            Glenville your town?
            You don't live that far from me, if it is.
            Edited 11/3/2009 9:43 pm ET by frammer52
  3. jimAKAblue | Nov 03, 2009 05:59am | #3
    Go on the roof and open it up through the plwood/shingles.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
