Hi All
I’m looking at fixing a roof for some friends. It’s a 1930’s mountain house. Poor construction at best. I’ll be ading some eve vents as well as improving the ridge vents, changing the valley flashing over to W style metal, installing drip edges where they were left out and probably replacing sheathing in some areas with obvious deflection. The reroof will be shingles.
I am still nor sure of one fix though. One of the valleys ends at the corner of the house effectivley driving water into the house. I think the valley needs to be moved. I was thinking of setting a ridge on top of the old one then setting new rafters on top of the old rafters, mitering the bottom edge so it will cross the valley and meet the other side of the roof, then cutting vents in the old sheathing, After the new rafters are coverd the valley should miss the side of the house. W style valley flashing should also help direct the water down not across the valley. One last step, the other side of the ridge should drop back down the back side of the roof a foot or so and be finished, like a stepped roof.
I am looking for better ideas though, anybody got one? Please see the images attached.
HC
Come for craft beer and a panel discussion! Friday, March 28, 3PM-5PM at Booth 727 The event will feature a casual panel discussion featuring some of the crew that helped…
Sorry, but no images attached and the verbal leaves some confusion
I lost you right after "I think the valley needs to be moved". If you can get those pictures to attach, I'm sure somebody will be able to solve this puppy for you.
Ooops
Maybe they will come through this time.
HC
This looks like a roof an architect designed for us a couple of years ago. We didn't build it as drawn. In your case if you simply raise the left roof 4-6 inches you will move the valley away from the wall.
Thanks for the pictures. I too am thinking you might be able to get away with an overframed cricket instead of raising the whole roof. I'm still trying to wrap my head around it and picture something that'll work...... maybe someone smarter than I will come along and bail me out before get hurt thinkin'. ;) That shouldn't be too hard to come up with around here.
NCGC, you have the priveledge of being the recipient of my first post on these boards, forgive me if I do something wrong.
As far as your problem goes, you are correct in that the valley is driving the water directly into the corner of the house, a result of poor framing. Essentially what they did was frame the valley too short of the corner, obvious i guess. Now your action will be to extend the end of the valley, what looks obout 6", to run past the corner, effectively guiding the water past the corner and into the gutter. Your solution of setting rafters on top of the old and messing with the ridge seema a bit excessive to me. All you really need to do is build a ramp/roof on top of the existing roof and run it past the corner, and you dont necessarily need to go all the way to the ridge with it. I cant see from the pics how long the valley is but I would say if you put the top of the *ramp* at about the halfway point(you could even come up as little as 2-3 feet from the end of the existing valley), and run the bottom past the corner about an inch you should be ok.
Now you can run the bottom past as far as you want but just remember, the more you go past, more of the side of the rafter will be showing and that will need to be finished with siding or roofing rolled over it(wich prolly wouldn't look too good). what I do is run my framing to the corner and then my sheeting extends past and that is good for me.
Framing: You dont necessarily need to cut rafters. On this type of fix, if you try to cut rafters you end up with ridiculous angles that are impossible to figure out let alone cut. If the *ramp* is small enough, and the pitch is shallow enough, you could nail 2x4's , perpendicular to the rafters , on the roof to create the ramp effect. I shouldnt say "2x4's" I should say"pieces of wood of varying thickness". Smaller strips on top gradually getting bigger as you get to the bottom of the valley.
Thenyou can nail the top of the new sheeting directly to the old sheeting on the top of the ramp, and run it over the "2x4's", nail it to them, then run it past the corner nailing it to the opposite roof on the bottom. I hope this doesnt confuse you or sound like a hack job but its probably the easiest and quickest way to do this short of cutting all new rafters.
*Just remember to make the new ramp solid, you dont want to walk on when finished and feel it being real spongy or squeaky.
What you are doing is creating a new valley line, its not going to be a straight shot anymore. It will be a littli cockeyed compared to the upper half and thats ok.
Now dont forget about the siding. You are technically raising the lower half of the valley, and that side butts the wall,so you will probably have to remove/cut the siding to get the new roof tight to the wall, then put the siding back up.
One note: If you are going to put new shingles down I would recommend pulling up the old shingles where you are going to be building the ramp, so to get a nice fit.
Sorry I was so long winded but like I said this was my first post and I didnt want to screw it up. Any other professional carpenters who read this tell me what you think. A fairly easy fix if you are familiar with roof framing no?
Thanx, Matt
As far as your problem goes.... a result of poor framing
Welcome to the forum.... but let's not start off on the wrong foot and go blaming the framer. Looks more like poor design than poor framing to me.
If I'm reading you correctly, the solution you are describing is often referred to as a 'cricket' around here anyway, and I agree that it's probably the best solution short of a tear off. The angles aren't too hard to figure out once you figure out the pitch of the roof you're framing onto and pick an appropriate roof pitch for the cricket.
No harm intended Diesel fore I am a framer too! And we refer to it as a cricket as well, I just couln't for the life of me remember it. I couldn't get "saddle" out of my head, ha.
Matt
Well, all right Matt! We can always use another framer around here. Click on your own name at the top of this post and then click "change your profile" and then go ahead and fill it out so we can get to know you a bit. Again, welcome to the forum.
of course it's the framers fault, dog-gone it! (he was s'posed to smack the architect, ya know....)
