I have a flat roof shop with an upstairs I would like to finish off. It is not practical to vent this roof in the normal manor. I have a parapet wall on three sides and putting a roof vent into each truss bay is not in the plans, trusses are solid with a top/bottom chord. My idea is to spray foam insulate against the roof and vent what is left inside the structure with a continuous vent along each inside wall. The appearance doesn’t bother me but is this a good idea? What other ideas for venting this are out there, or is it acceptable to simply sheet rock the inside and forget it? This area will be heated as a finished structure.
With the right approach, you can restore old hardware—whether through soaking, scrubbing, or polishing—giving it a fresh look while preserving its original charm.
