roofing procedure
| Posted in General Discussion on June 11, 2001 06:22am
The 2 year old roof on my new house is not up to the rigours of ice dams.
There is a 3 foot wide strip of light felt at the eaves and a conventional asphalt shingle job with 25 year shingles. However, last winter there was an ice build-up in the soffits either side of the two valleys and ice on the stucco walls below. I am prepared to tear up the shingles 4-5 feet back back and put down ice shield but I am unsure of what to do at the edge. I’ve been told to remove the eaves trough and apply the ice shield down the fascia board several inches so as to seal any gaps between the roofing sheets (1/2″ plywood) and the 2×6 fascia – then cover it with drip edge. Is this necessary or will a good drip edge with ice shield on top do the same job. I’d rather not cut the trough down but I want to do it right
the second time. Advice appreciated. Lawrence Cotton [email protected]
  1. Lawrence_Cotton | Jun 11, 2001 06:22pm | #1
    There is a 3 foot wide strip of light felt at the eaves and a conventional asphalt shingle job with 25 year shingles. However, last winter there was an ice build-up in the soffits either side of the two valleys and ice on the stucco walls below. I am prepared to tear up the shingles 4-5 feet back back and put down ice shield but I am unsure of what to do at the edge. I've been told to remove the eaves trough and apply the ice shield down the fascia board several inches so as to seal any gaps between the roofing sheets (1/2" plywood) and the 2x6 fascia - then cover it with drip edge. Is this necessary or will a good drip edge with ice shield on top do the same job. I'd rather not cut the trough down but I want to do it right
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
