Roofing, Rip old roof, ?resheath over…
| Posted in General Discussion on August 8, 1999 07:54am
I am estimating a roof which shows signs of
sheathing delamination. This is due to a lack of
attic ventilation and insulation between rafters
laying up against the sheathing. The roof was
originally cedar, rafters 27″ OC, and was stripped
about 15 years ago, including 1×2″, and sheathed
with plywood directly over the rafters.
>My question concerns cost. I would rather remove
the existing 1 layer roof, resheath over the
existing plywood with 5/8″ ply, cutting away
damaged sections, rather than remove all existing
sheathing and resheath with 3/4″. The house is
tall, steeply pitched.
>Advice as to suitablity of sheathing over
existing sheathing would be app
  1. Guest_ | Aug 07, 1999 06:16pm | #1
    James, is the plywood delaming all over or only in certain places?
    1. Guest_ | Aug 08, 1999 02:26am | #2
      *if the roof is not too bad(delamination is limited to only a few areas) then it would be ok to sheet over, however i would screw the new deck down to eliminate any future problems.
      1. Guest_ | Aug 08, 1999 02:37am | #3
        *James,what size is the existing plywood and how big are the rafters? 27" on center sounds alittle much to me.But, I also don't see a problem with plywood over the existing as long as you replace the bad spots.Vince
  2. Jim_Blohm | Aug 08, 1999 09:04am | #4
    Thanks for the prompt responses.
    Delamination appears to be limited to a few
    areas. I planned to cut away the bad areas,
    shimming up the rafters in those areas.
    Thom Day, what concerns you that you prefer
    screwing the deck down? I had planned on using an
    Hitachi pneumatic framing nailer with 3" galv.
    full head nails.
    I am not certain what the thickness of the
    existing plywood is. I would hope that it is at
    least 5/8" or 3/4". The rafters are 2x6, with a
    pitch of 10/12. I have found odd ball rafter
    spacing before when wood shingles were the
    original roofing system in houses built in the
    early 1
  3. Guest_ | Aug 08, 1999 07:34pm | #5
    I have done what you propose several times with really good results,so I would not hesitate to do it again.(In fact I will be doing an insurance job this way in a few weeks)What I find is that the delaminated plywood is 3/8",the wood fibers still good but the glue non-existent.Screws would make good fasteners but we use nails.(used to use a gun exclusively but now we handnail a lot).
    As long as the delamination isn't rotten or bubbled up so high as to prevent a smooth plane in the new layer of decking I wouldn't even be to worried about cutting out the delaminations.I would nail the snot out of it though.
    Problems like this with plywood delaminating after one water exposure are why I switched to properly spaced osb about 6 years ago.
    Good Luck,I am sure your job will go fine,Stephen
    1. Guest_ | Aug 08, 1999 07:54pm | #7
      *James,I'm wondering if sheathing over the old sheathing is warrented if you are going to replace the bad areas anyway. With 2x6 rafters on odd centers, I might want to consider the extra weight factor of another layer of decking. If the original decking is 3/8" as suspected, I wouldn't want to see you put anything more that another layer of 3/8" on top of that unless you beef up the purlings.Just a thought,Ed. Williams
  4. James_Blohm | Aug 08, 1999 07:54pm | #6
    originally cedar, rafters 27" OC, and was stripped
    about 15 years ago, including 1x2", and sheathed
    existing plywood with 5/8" ply, cutting away
    sheathing and resheath with 3/4". The house is
