In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
rousseau or makita porta-table saw stand
gcrow | Posted in Tools for Home Building on February 18, 2008 07:47am
picked up an old rousseau, or makita porta-table table saw stand.  the hinges are a little sloppy. the fence handle doesnt lock down real tight. no manual or instructions.  its the one for the old makita 2708 8 1/4 in portable table saw. does anyone have an old manual or set-up instructions.  also does anyone know how to tighten up the fence handle, and take some of the slop out of the leg hinges. any info would be greatly appreciated.  thanks gerry
  1. Tomrocks21212 | Feb 18, 2008 08:02am | #1
    The Rousseau is a good table, I've had mine since the early 90s. You may be able to adjust the 2 Allen screws to get more tension in the fence cam (the screws that adjust for square). Is the tension leaf spring in place? If it's missing, you may be able to get a replacement part from them.
    As far as the leg hinges go, I've managed to tighten mine up by peening the rivets slightly with a hammer. Back up the other side with the head of a sledgehammer, and tap the rivet. It shouldn't take much.
    If the rivets are too far gone, I'd try drilling them out and replacing with bolts, lock washers, flat washers, and Nylock (aircraft) nuts.
    I just picked up a free 2708 that needs a rebuild, but I've always wanted a spare for dedicated set-ups. Be starting on the rework soon.
    1. gcrow | Feb 19, 2008 07:36am | #6
      thank you tom, that 2708 and a resseau is a great combo.
  2. JulianTracy | Feb 18, 2008 09:53am | #2
    All of their products have a lifetime warranty - might be worth a check with them how they handle it.
    JT
    1. gcrow | Feb 19, 2008 07:37am | #7
      thanks julian, ill give them a call. their company seems like a nice group of folks. gerry
  3. Jer | Feb 18, 2008 02:55pm | #3
    The allen screws in the fence near the handle also align the fence to parallel the blade. Important that the leaf spring piece is in place against the front rail when you put the fence on.
    I've had mine since the mid 90's and it's still going strong.
    1. gcrow | Feb 19, 2008 07:39am | #8
      thanks jer, when i go to put the fence back on the rail i have to push the tension spring in , on each side , in order to get it to snap onto the square tubing.
  4. RichMast | Feb 18, 2008 07:19pm | #4
    I have a knock off of the rouseau stand, and to tighten up the fence lock there is a bolt direcly behind the handle (you can't see it unless you flip the fence over) which can be adjusted and has a lock nut to keep it in place.  it kind of looks like a carriage bolt head, pushing on a pressure plate which bears on the rails.
    Flip the fence over and have a look.
    Hope this helps.  Rich
    1. gcrow | Feb 19, 2008 07:34am | #5
      thanks rich for the info, gerry.
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
