Sagging ceiling/roof
weej55 | Posted in General Discussion on August 1, 2020 03:43pm
I recently purchased a single story ranch style modular home built in 1969. Interior dimensions are about 22 1/2 x 47 feet. The roof is 4/12 pitch. It is located in upstate NY.
In the living room/dining area there is a 21′ 5″ open span which sags about 2 3/4″ in the center. This appears to be original construction, neither myself or the inspector I hired could find any evidence that there was once a load bearing wall, support post etc. There is a main “beam” running down the center of this space (see image) consisting only of 2 2×4’s on edge. This beam is in the center of the house running perpendicular to the trusses.  I believe this is where the 2 halves of the house were connected.  The smaller beam to the left of the main one is one of many decorative box beams that I am in the process of removing.
The inspector was confident that it probably wouldn’t get much worse over time given that it’s been around for 50 years and is still solid. I don’t, however, like the look of the sag and am worried that If I were to sell the house it might scare away potential buyers.  I also want to make sure that it doesn’t get any worse.
I have come up with a potential fix – there is a good, convenient spot to add a support post which would almost split the span in half (10′ on one side, 11′ 5″ on the other). There is a solid support post in the crawlspace directly below this spot as well.
My question is: would it be possible to replace the beam with something sturdier like an lvl and jack up the 2 3/4″ sag without breaking/cracking anything above? I would then use the support post to transfer the weight down to foundation. OR would it be better/safer to leave things as they are, add the post so it doesn’t get any worse and maybe reinforce the existing beam. I think I could box it In and simply make the sag less noticeable.
The post shown in the picture is just something temporary I put in.
Any suggestions would be greatly appreciated!
  1. bing0328 | Aug 01, 2020 06:25pm | #1
    What I have done in a similar situation is remove plaster ceiling and install a steel "C" channel with 1-1/2" flanges and 3-1/2" side sistered to a existing 2x4 every four feet. Get the channel up in position use Simpson lag screws and with clamps screw each ceiling joist to the double 2x4 "main beam". Then using a 20 ton bottle jack jack up starting in center each 2x4 ceiling joist until it is flush with the C channel. Use Simpson lag screws to screw 2x4 to C channel. As you move out from center the ceiling joists will "unsag". Los Angeles City inspector signed off on this and the sag was reduced to about 3/8".
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
