In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Saturation & frost outside above grade foundation
thisagain | Posted in General Discussion on December 13, 2019 04:40pm
Hi everyone,
We moved into a newly built house 13 months ago and when Winter hit, we started getting freezing/frost on the outside of the exterior wall.
The parged portion is poured concrete and the brick portion is the framed section.
Concrete below grade has exterior rigid foam. Concrete above grade has rigid foam on interior + fiberglass insulation + vapor barrier. Framed portion has wrap, rigid foam, fiberglass insulation and vapor barrier.
After consulting a few people, they came to the conclusion that it was the concrete releasing moisture and freezing. It’s been 18 months since the concrete was poured (poured in May/June). It’s happening again this year now that winter has started.
The base of the interior of the garage wall on this side becomes saturated/wet to the touch and freezes/frosts up. Running a ventilation fan in the garage has helped with this. The saturation starts at the back of the garage and wicks towards the front. The back of the garage is where the first step down on the foundation.
Under the garage is unexcavated, after the first step down is a finished basement room.
Using an infrared camera inside the house in the room that’s in the lower right, there’s nothing that looks too out of the ordinary behind the wall.
I’m not sure where this moisture is coming from. The exterior infrared image seems darkest where the basement room is finished. The unexcavated isn’t as frozen. The first image (wall.jpg) is from last year, the remaining ones are from today. It’s not as bad as last year yet, but still early on. We’re at about 34% RH indoors.
I’m not sure what to do / how to source the issue, but would love to know what’s going on and hopefully solve it. Has anyone seen this happen / have any ideas?
I’m also trying to figure out when it happens – it’s possible that the saturation happens when it gets a bit more mild out and then wicks up. It was hovering between just above freezing and just below freezing the past 24 hours after a fairly good cold snap. I looked up the historical weather from last year when I took that photo and it looks like the same. This could be coincidental, but in case it helps.
Thanks in advance
  1. joesmith17 | Dec 14, 2019 01:20am | #1
    Sounds like the water on the outside of the concrete wall is just condensation. Since the concrete wall is insulated on the interior with both rigid foam and fiberglass insulation, the exterior wall face remains cold because little heat from the interior reaches it. Since you indicated there is a vapor barrier between the concrete and the interior insulation, there is little worry of inward vapor drive. However, it's possible that interior moisture attempting to migrate to the exterior, if the interior rigid foam insulation is not air sealed, is reaching the cold vapor barrier and condensing on the inside of vapor barrier. The thermal image seems to pick up more moisture on the exterior than interior, but that may only be due to drying from indoor heat.
Small, Problem-Solving Square
Get accurate measurements for fine finish-carpentry work with this precision furniture-maker's tool.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
