Does anyone know of a Schluter -Kerdi distributer in southern Ca. Tried calling different tile supply places and I am not having any luck thanks for the help
you can always order it thru the Depot if you can't find a local stocker
Tried that at the local h-d and got the "what are you talking about look", after some real bad experiences I try my best not to shop at the big boxes. thanks for the response though
If you want to order online try http://www.tile-experts.com/
Prices are about the same as at my local tile shop.
Regards,
Dennis
What are you doing at your computer, aren't you supposed to be putting in some wainscoting!
I was at the real job at the time. But I was thinking about the wainscot. I got half the chair rail/top moulding put in this morning. I gave up on the fancy returns on at the casing though. The return is only about a half inch square and I got tired of searching for them after the chop saw sent them shooting across the garage. I did a 30 degree cut on the bit that sticks past the casing and it looks OK. Probably not up to your standards but Jose would think it looks good. :)
Dennis
And after all, what else matters!
