As a Construction Window Cleaner for more than 35+ years, I would like to shed some light on some possible sources, for the majority of scratched glass in the housing industry.
If you are experiencing an excess amount of scratched glass for no apparent reason, you might want to check to see if all your scratches are in tempered glass only.
If so, it is very likely that the tempered glass in question has debris fused to its surface during the tempering process, which causes scratches when cleaned by a qualified window cleaner.
This problem is a growing one and need to be addressed by all.
