Not a whole lot of content here, just wanted to share a very positive experience I just had.
I’m adding a bathroom to the basement, and recently installed the lines for the sink + toilet. Used 1/2″ PEX and then used SharkBite connectors to tie into the existing hot & cold lines.
Just to preface things, I hate plumbing as I always end up with leaks. Matter of fact, on my itemized list of activities for the bathroom, I had:
*connect new lines to old
*turn water back on
*pray
Third task wasn’t needed. No leaks! Totally easy connection splicing a tee into my existing lines. I gotta admit that sharkbites are pricey, but wow, do they make things easier for you!!!
Thanks for letting me share!
Glen
Did ya know that you can remove them and re-use them? They make a small tool for removing them. Prab'ly not 50 times but ya can use em several times. I use em alot to cap lines in bathroom renovations.
Worth every penny!
dug
yeah, I just messed shark bite today in a crawl space. Wasnt going to bust out the mapp in that small of a space and didnt want to mess with compression fittings. No problems at all amazed at how fast I was done. Very $$$$ though.
In europe electrical connections are this easy...(i think).
ain't they great.... in the freezing winter (as much as we have here) i had a leak in an empty retail space... was just luck i even saw it... 3/4" copper beside a furnace an old line to a HWH that was no longer there... it's an old strip center and i have no idea what spaces are tied to what meter this place was built before the area was even a city and there was zero codes...
anyway.. with a 3/4" shark bite connected to a 3/4 ball valve on one side... i cut the leaking part out of the line with the water on ( i was dressed in a 55gal garbage bag) slipped on the shark bite with the valve open then closed the valve.... less than 10min total yeah i got kinda soaked but... i was 50 miles from my tools it was dark... and i happen to have the stuff to do this with me...(did it by flashlight) it might be $$$ for the fitting but it saved me a return trip... easy to say it saved me half a day because i was already there... i didn't have to hunt down the cutoff and hope it worked... never was so happy to get a little wet and be done with a problem i didn't even know i had...
I'm sold on em
p
