Sheet Rock Texture/ Repair
RPAdams | Posted in General Discussion on September 20, 2006 02:22am
Good Morning to all,  I recently cut my garage ceiling joist in half and put in a 5×16 lam beam.  I replaced the sheet rock that I cut out and installed some new rock also.  The ceiling has a spatter finish.  My question is how to match up the finish without leaving a big seam.  Should I sand off the old texture and tape or just go over it??  I would like it to look halfway decent.  Thanks for any and all tips…..Randy
    Fonzie | Sep 20, 2006 03:21pm | #1
    We have successfully done this several times. The texture needs to be removed enough to tape/finish the joint. The new drywall needs to be taped/finished decent (garage quality).
    In the area of the transition the texture needs to be tapered back for 12 inches or so from full texture to nothing. Sometimes this can be pretty well done with a paint scraper (I have a carbide one that's not too sharp that works well).
    We do the spraying with a hopper that has a "blow gun" hooked in right at the hopper. Also I leave the quantity flow adjustment open so I can vary the texture (the farther I pull the trigger the bigger the texture). I match the area of the transition in small bursts - checking in between. Good luck.
  2. CraigF | Sep 20, 2006 03:50pm | #2
    A dip or a ridge will show up more than a variation in the spatter texture. Taper the seams out 12" ea. side. Your knife will chatter on the old texture, leaving marks. Fiddle around filling the marks and blending in with a sponge.
Double-Duty Large-Jaw Pliers
Klein's 10-in. plier wrench has a toothed V-jaw for grabbing pipe and conduit, or can be flipped around for a parallel, smooth grip.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
