In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Shim Shim Shimboree – Wavy Walls Cabinet
chefwong | Posted in General Discussion on July 3, 2006 08:16am
So any tricks you guys can advise when dealing with old walls that are wavy, etc – just short of tearing it down and starting from scratch.
I’ll be swapping old cabinets for new but the walls is definately wavy.
Luckily, the worst of it is a hump but the stove and hood is there. I still may need to tweak it as the stove sits FLUSH against the wall.
So any tips/advice or it’s just a matter of shimming galore when it comes down to installing the cabinets. I can see how you can shim the bottom on the uppers and also the bottom front and backside of the base cabs.
How do you guys shim the top of the upper cabs or the back of the bottom on the base cabs given no room/clearance ?
  1. Shep | Jul 03, 2006 09:51pm | #1
    Pull a line for the uppers at the height you want to run the screws. You'll probably have to shim out the ends to get a straight line.
    Then tack shims at the studs, using the line as a guide.
    Set the upper cabinets, screwing the uppers thru the shims. Then plumb the cabinets, shim along the bottom edge, and run screws there.
    I don't bother shimming along the bottom edge of lower cabinets. Just set the lowers in place, get them straight and level, and shim where needed and the fastening strip.
    It varies from person to person, but I like setting the uppers first. That way I don't have to reach over the lower cabinets to work on the uppers.
  2. RichMast | Jul 04, 2006 04:48am | #2
    Depends.  For uppers I like to build them up as a unit on the ground, nice and tight, and then install the whole run as a unit.  Helps to have extra hands around.  Then just screw at the high points, and up into the ceiling.  sometimes a piece of scribe molding is needed at the end of the run.
    For lowers you can always screw into the floor if you can't reach the back to shim.
    Hope this helps.   Rich.
    trout | Jul 04, 2006 09:01pm | #3
    On our kitchen remodels we automatically tear out the sheetrock/plaster for just this reason.  Besides, there are always outlets that could be moved/added and other such nonsense.
    As for just fighten it...well...good luck with that.
  4. bps | Jul 04, 2006 10:04pm | #4
    Listen to Richmast.
    1. dukeofwsu | Jul 04, 2006 11:49pm | #5
      Richmast, or on long runs and without a lift, hang a full sleeper top and bottom of 5/8 ply let into your wall cover.DCG Your Neighbor's Contractor LLC"A wrongdoer is often a man who has left something undone, not always one who has done something."--Marcus Aurelius
        Huck | Jul 09, 2006 12:04am | #6
        "...hang a full sleeper top and bottom of 5/8 ply let into your wall cover"
        whats the benefit of that - it'll just follow the same irregular path as the wallcovering?"he...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
    Sphere | Jul 09, 2006 01:24am | #7
    I am betting you have plaster , not sheet rock. With sheetrock, cutting it out is an option, plaster, don't touch it.
    Shim away. And get good at scribe moulding.
    There is no cure for stupid. R. White.
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
