shingling bays
thebozer | Posted in Construction Techniques on March 2, 2007 01:38am
i’ve been doing alot of sidewall shingling of late. i’m getting pretty proficient at weaving corners and my work is speeding up quite nicely. i’ve got a walkout bay to do which i’ve just got started on. The angle on the bay is 135 degrees so a 45 bevel works for the weave. I’m wondering what techniques/tips BTers might offer for this application.
I’ve been holding up the shingle, tracing the back with a sharp pencil, then running it through the tablesaw, following the line on the back which is the long point of the bevel. anythign else? thoughts?
  1. Piffin | Mar 02, 2007 02:01am | #1
    I just nail it up with excess, then use sharp utility knife to trace the cut. I start at bottom and look at the tip cutting through so I can see how to guide the knife. I leave it about an eighth long, then use block plane to finish shaping, all with shingle already nailed up.
    Harder to get my table saw up on staging than just a knife and block plane.
    1. thebozer | Mar 02, 2007 02:21am | #2
      yea, that's the issue i've been facing. thanks.
  2. yammy | Mar 03, 2007 09:25am | #3
    I had an old timer that did amazing shingle shaving using a shinglers hatchet.
    he would sharpen it on a grinder,and tune it up on a wetstone.
    He would hand shave all the hips and ridges,weave corners on dormers,using the hatchet,bumping the hatchet head with his palm to shave the shingle.
    on hips he would tack on a strapping board as a guideline on either side,shaving the excess.
    I have also used a drawknife to shave with,mostly for ridges as you have to pull it towards you.
    1. MikeSmith | Mar 03, 2007 06:25pm | #5
      yammy.. i was taught with a shingling hatchet.. still have mine..
       the biggest problem i had with it was where to hang it.. put it in a hammer hanger.. and you'd lay your forearm  open from wrist to elbow with one  wrong move
      you could literally shave with it.. the usual test was would it slice a piece of paper Mike Smith Rhode Island : Design / Build / Repair / Restore
        Sphere | Mar 03, 2007 06:32pm | #6
        Yeah buddy..I was doin that Oak shake roof about 3 yrs ago. A real pissah..I use a half hatchet that is razor sharp. As I was sliding my self down to the next set of planks, the edge sliced my heel of my thumb right open...7 stitches.  And the er visit was 750.00$
        1. DougU | Mar 04, 2007 06:01am | #7
          Do you ever do anything where you dont get seriously hurt!
          Damn man, you get injured more then anybody I know.  You ever think about office work. <G>
      2. Piffin | Mar 04, 2007 07:12pm | #8
        What I used to end up doing was snag the brim of my ball cap swinging the hatchet to drive a nail. Yanking forward on that hat gives a guy a sore neck after a while.Makes hat look beat up too.
  3. arnemckinley | Mar 03, 2007 06:02pm | #4
    i basically do a combination of what you and piffin are talking about. i'll trace both sides of the corner and cut five courses worth on the table saw, 10 shingles, 5 at  with the  angle on the right 5 with the angle on the left. when i get about three shingles from the corner i throw the corner piece in and then fill in, same on coming from the other side. there is less hand planning this way, though i have done plenty of shingling without using a table saw, and just a knife and a block plane :)
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
