SUBSCRIBE TODAY
Save up to
70% off
the cover price
In-depth articles, up-close photography, and detailed illustrations in every issue.
Subscribe Now!
shop ceiling and insulation ideas
Troubleshooter | Posted in General Discussion on January 27, 2021 04:58pm
Barn looks like this. I will either cover the ceiling with sheet metal or sheetrock. For insulation I would like at least R30 maybe R38 (southern CO).
If I go with batts I will install them myself and then have the metal or sheetrock installed.
How would you install the batts? Staple clear plastic underneath the trusses and then lay the batts in from the top side? Looks like R38 comes unfaced.
If it had a paper face I could staple it from the bottom but plastic is probably easier anyway. How far could a contractor blow insulation if I went that route? It would be hard to climb up into the trusses and blow it I think.
For walls probably 2″ foam and then R13 batts or just R19. If R19 do I cover insulation with vapor barrier?
Barn is 40 x 40 but I plan on only insulating one side and the center. I will put a hanging shop curtain or tarp to partition off the other side. So the heated area will be about 1200 sq ft with 12′ ceiling for 600 sq ft and above the roll up doors probably 14′ for the other 600 sq ft.
I will heat with a large wood stove during the day and have a hanging shop heater. Will also replace the two 10×12 rollup doors with insulated doors- probably R9
  1. SteveL_MI | Jan 28, 2021 08:00am | #1
    If this were my space, I would buy a drywall lift and put 4'x12' sheets of 5/8" drywall on the ceiling first and then insulate to R50 or whatever is recommended. I had a project like this and I paid to have cellulose blown in even though I did every other part myself. I would not replace the doors until you have everything up and running. My guess is you will be plenty comfy without the insulated doors as long as they are fairly air tight.
    1. Troubleshooter | Jan 28, 2021 09:58am | #2
      Thanks. Looks like the HF drywall lift doesn't go to 12' so will have to look for another affordable one
How to Hire and Retain Good Tradespeople
It's common to hear how hard it is to find quality tradespeople. Learn how your approach to roles, training, and career goals can enable your business to find and retain the best employees.
  • Podcast 471: Members-only Aftershow
  • Podcast 471: Adding Outsulation, Sealing Leaky Bump-Outs, and HVAC for a Shed Office
  • Schneider Electric Recalls Line of Electrical Panels
  • Podcast 470: PRO TALK With Builder Mike Knoche
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
