shower drain
jyang949 | Posted in General Discussion on January 19, 2008 01:48am
The builders did not use caulk in the shower; all the corners and transitions are grouted.
I lifted up the square plate that frames the drain and found a ¼-inch layer of grout under that, too. It was cracked so I cleaned it away, down to the mortar.
We have another shower and its plate covers a layer of plumber’s putty. Now I don’t know what is supposed to fill in the space under the plate. Plumber’s putty, mortar, or grout?
Janet
  1. MikeHennessy | Jan 19, 2008 04:40am | #1
    Doesn't really matter. Unless you want to level it, the cover doesn't need to be watertight or fixed in place, so you can leave it loose -- helps in cleaning the drain if needed later as well.
    The water seal is below the level of the drain cover -- it's at the level of the shower liner, usually an inch or so below what you see.
    Some folks (even some recognized experts) prefer grout at the corners. For me, it depends on what's behind the tile.
    Mike Hennessy
    Pittsburgh, PA
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
