Shower Install Drain help
jon94706 | Posted in General Discussion on February 13, 2006 09:29am
I’m installing a shower where a toilet was previously located and there is no trap in the floor.  The drain is in a concrete slab and there’s radiant floor tubing in the slab so I don’t want to cut concrete to install a p-trap.  Somebow, I need to get a trap in there and I just don’t have room for a traditional trap.
Several months ago I read an article in Fine Homebuilding about a “trap” for exactly this situation, but now I can’t find that issue.  It looks like an ABS union but it has a “sock” or rubber sleeve that hangs down and prevents sewer gas from coming up.  It allows drain water through, but closes up afterward, thus eliminating the need for the traditional p-trap.
What is this thing called and any suggestions on where I can buy one on-line and get it by this weekend?
Thanks!
Jon
    Soultrain | Feb 13, 2006 07:58pm | #1
    What about using a bell trap instead of a P trap?
    http://www.oatey.com/apps/catalog/showskus.asp?ctg=11&subctg=25&prodgrpid=371#
  2. dallasfred | Feb 13, 2006 08:06pm | #2
    The one I saw was in JLC.  Thhe name on this one is ProSet Trap Guard, the company name is ProSet Systems 800.262.5355 and their web is http://www.trapguard.com
    1. jon94706 | Feb 13, 2006 08:38pm | #3
      Thanks!
      That's exactly what I was looking for.
      1. MikeInVT | Feb 14, 2006 02:08am | #4
        That's not meant to replace a trap. It's purpose is to prevent the trap seal from evaporating causing sewer gas to escape into the living space.
        JeffBuck | Feb 14, 2006 03:31am | #5
        looks to be a floor drain ...
        not a shower drain.
        sounds like a hand-dig job thru the concrete.
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
          Soultrain | Feb 14, 2006 04:53am | #6
          Why would that matter?  Wouldn't you just end up w/ an oversized shower drain?
          Regardless, I'd go w/ the bell trap instead like I said before (unless this was a seldom used shower).  It would be less $$ & you can pick one up at the local hardware store.
Mortar for Old Masonry
