I’m in the process of rebuilding a steam shower. It was built with all the mistakes, ie. no preslope under the pan, no water proof walls, wood studs used to support the seats, steam head under the seat ( super mold and rot!!), level ceiling, The old lights were very rusty and are scrap. What should I use? I don’t like the idea of cutting holes in the new tile for new lights. As one side of the shower will be all glass, I was thinking shinning light through with directional spots would be a good fix. What do you think?
The best tool for straight, splinter-free cuts is made even better without a cord.
There are sealed light units, specifically for wet areas, that can be purchased. They are similar to those used in a pool and will stay dry.
MES
I know the sealed type and looked at some. They were listed at $550 each. A little high for this job.
If you can stand the look you can use glass jar (now plastic) barn lights.
https://www.farmtekcatalog.com/lg_display.cfm?page_number=64
If you go back to the can lights then make sure that you get one that is AIR TIGHT, INSULATION CONTACT.
