I will be installing 12 x 12 slate tile on the walls of a shower. I just installed the durock and one of the studs had bowed about a 1/4″(framing was installed 8 months ago and was straight). Should I float the wall with thin set now when I fiberglass tape the joints or should I wait and use a thicker bed behind the tiles at the bowed stud. Will there be a bonding problem with the durock/thin set and the tile thin set if I do it now?
Thanks for any (well almost any) response.
Rd
I will be installing 12 x 12 slate tile on the walls of a shower. I just installed the durock and one of the studs had bowed about a 1/4"(framing was installed 8 months ago and was straight). Should I float the wall with thin set now when I fiberglass tape the joints or should I wait and use a thicker bed behind the tiles at the bowed stud. Will there be a bonding problem with the durock/thin set and the tile thin set if I do it now?
Rd
