I just installed a new white porcelain sink over a black fomica counter top. What type/brand of caulk should I use to seal the gap between the top and the edge of the sink?
Thanks, Mike
Thanks, Mike
Listeners write in about sanding drywall, replacing a failed foundation, and making ground-contact PT posts last longer.
I'd probably use silicone. Or I'd inquire about plumbers putty.
Since you just installed it, it's a bit late. Best to set the sink in the caulk, then clean the excess.
Smelly cone will do the job. Most sinks actually come with a smallish squeeze tube colour-matched.
If you have to buy it, might as well use clear for your combination. run blue painter's mask around on the counter first, then cut a tiny tip off the silicone tube and knock yourself out, tool it down and then carefully peel the tape.
to clean a little bit off here and there, white vinegaar on a rag.
I did put a bead of white silicone caulk on the underside lip of the sink - a little squeezed out when I put weight on the sink to set it. I like the idea of the painter's tape since I am not a caulk 'artist'. Thanks, Mike
Yeah, normally a self-rimming sink is installed with a bead of silicone caulk under the rim, before installation. Even with it installed you might be able to prop the sink up slightly and squirt the caulk under the rim.
