Our 1923 house is t & g – 3″ wide. A friend is suggesting the skim coat and another doing the drywall route.
Skimming is much less expensive, but I would like any input you’ve got a minute.
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
SKIM AND EVERY SINGLE JOINT IN THE WOOD WILL TELEGRAPH FOREVER, MAKING IT LOOK LIKE HELL.
if you rock over it, the skimming will be three times as easy
Thanks. My wife and I were leaning towards the drywall part.
BTW, is that normal to "skim" after one rocks? We were planning on spraying texture after tape and mud, whatever way we choose.
Localy, it is, because plaster texture is preferred.
Thanks. Never done this so it will be interesting.
IMHO the only reason to do it yourself would be because it is interesting. Drywalling and taping, I think, is at the top of the heap when it comes to value recieved for $ spent on hiring it out. After you've lugged a few sheets around, missed or roughly cut a few electrical boxes, gone through a screw gun or two, taken xxx milligrams of ibuprofin...AND YOU'RE STILL NOT DONE, it won't seem so interesting anymore.
If you have time, (and I've always wanted to do this) go to a construction site when they are hanging/taping sheetrock and watch an experienced crew do this. Your main problem will be timing because they'll be done by the time you get there. Then get a quote or two.
But, if you really want to find out how interesting it is, I've got a few taping tools that I would let go cheap.
Thanks. And I would too; if we could afford it. It's been a nearly four year project - piece meal.....
they make a plain wall paper material for this job...thicker than normal paper and finishes up pretty nice... might be cheaper and look ok
p
