Slot in Door – What was there?
marcwd | Posted in Energy, Heating & Insulation on October 14, 2005 04:58am
The solid wood front door of my 1920’s Colonial has a slot in the bottom edge of the door that runs its entire width. The slot dimensions are roughly 1″ deep and 1/2″ wide. (See attached pic.) As can be seen, there are a couple of screw holes above the slot.
What was originally in this slot and how might I utilize it now to fill the gap between the lower door edge and the threshold for insulation purposes? I’ve looked around for a very thick piece of felt to glue in there but haven’t been able to find anything suitable.
  1. calvin | Oct 14, 2005 05:10am | #1
    There was a "operable weatherstrip mechanism" in that groove.  The holes held the screws to secure it.  You are right on the felt strip.  The mechanism had a pin that stuck out on the hinge side.  When the door was shut, the pin would depress and the weatherstrip would drop down to the threshold.  Open the door and a spring would pull it up.  If you check through a catalogue at a good old hardware, they might just make them still.
    Quittin' Time
    1. marcwd | Oct 14, 2005 05:39am | #2
      Thanks, Calvin, that's exactly it! I looked at the door jamb on the hinge side and, sure enough, there's a dimple there caused, no doubt, by the pin you described. Just curious, what was the material of the weatherstrip that dropped down?
      I'm surprised that you think that there might still be a possibility of finding such a replacement mechanism. I suppose it's worth a check though. Otherwise, I take it that you think that my felt idea would be the way to go.
      1. calvin | Oct 14, 2005 05:56am | #3
        Well, from what I have seen on the few with the guts still entact...........if I remember right.  A thick felt pad, maybe a qtr thick by 1/2 to 3/4 tall.  Stiff.
        The only felt stripping I have seen lately is too flexible.
        There used to be a couple hardware (catalogue) suppliers.  I would start there.  One, Bostwick Braun and the other Worthington.  Don't know if both are still in biz.  You could order through a catalogue at any hardware.  Pro and Ace have the ability I think.A great place for Information, Comraderie, and a sucker punch.
        Quittin' Time
        1. marcwd | Oct 14, 2005 06:13am | #4
          Great, thanks again, Calvin. I couldn't find Worthington, but Bostwick Braun is still around. Will try searching their catalog for "operable weatherstrip mechanism." 8-)
          1. RalphWicklund | Oct 14, 2005 07:23am | #5
            Here's a start for ya...
            http://www.customaudiodesigns.co.uk/seals/thresholds.htm
          2. BillBrennen | Oct 14, 2005 07:28am | #6
            marcwd,Do a Google search for "automatic door bottom", in quotes. 721 hits, first 5 were relevant, and I looked no further.Bill
      Sailfish | Oct 14, 2005 04:38pm | #9
      was that slot/mechanism around in the 20's or was it something done at a later date?
      just wondering-----------------------------------------------------------------------------
      WWPD
      1. marcwd | Oct 14, 2005 06:25pm | #10
        Thanks for all the replies and suggestions. After some web checking and calling around, I learned, not surprisingly, that I'm not likely to find a "drop-in" replacement for the original mechanism. I don't have the means of reworking the existing slot dimensions to accept a differently-sized mechanism.
        Seems that my best options are 1) stuffing some heavy felt in the slot, 2) attaching a vinyl strip to some wood, as suggested, and fitting it within the slot, or 3) attaching a commonly-found vinyl sweep with an aluminum mounting strip to the lower inside edge of the door. Problem with the last one is that it's likely to look rather ugly.
        Again, thanks for enlightening me about this.
        1. RalphWicklund | Oct 14, 2005 06:38pm | #11
          <<I don't have the means of reworking the existing slot dimensions to accept a differently-sized mechanism.>>
          Explain this, please.
          Mechanisms of diferent sizes are still available - see the link I provided - and if the door is wood and you own a pocket knife you can do it.
          I would, if I didn't have the power tools that everyone assumes are required these days, obtain a simple, sharp chisel and a hammer and modify the slot to accept the product.
          1. marcwd | Oct 15, 2005 12:29am | #14
            Ralph, you're right. With a little gumption, I should be able to rework the door. The slot will have to be deepened, probably, as you suggest, with a chisel. Will likely have to rent a sander, though, to take some material off the bottom of the door for mounting screw clearance.
            Thank you.
        2. BryanSayer | Oct 14, 2005 06:45pm | #12
          You might want to chat with Bill Rigby, at [email protected]
          If he doesn't have a solution for you, I'm sure he will be interested in hearing about the door.http://www.wmjrigby.com/index.php?cat_id=75&nav_tree=75
          1. marcwd | Oct 15, 2005 12:36am | #15
            Bryan,
            I did talk with Bill Rigby. He knew of the door bottom mechanism but doesn't carry anything like that.
            He solved this type of insulating problem at his home by adding a wooden lip to the threshold for the door bottom to close against and applying a strip of pliable material to the lip for compliance.
            Thank you.
        3. reinvent | Oct 14, 2005 07:22pm | #13
          You should look at Pemko. They have a whole bunch of differnt sizes. Dont use felt. It will make the door very difficult to open & close, get dirty, absorbe moisture, etc.
          http://www.pemko.com
          1. marcwd | Oct 15, 2005 12:47am | #16
            Pemko was very helpful in helping me select a suitable product from their catalog. The cost through a distributor would be close to $50. In addition to modifying the existing slot, I may have to remove some of the door material (increase the gap) in order to have room for the mounting screws.
            I thought the felt idea was good, but maybe you're right that it would make it difficult to operate the door.
            Thank you.
        4. Piffin | Oct 15, 2005 04:26am | #20
          I installed two of theses a couple years ago. I think I got them from conservation resource technologies who had half a dozen sizes and varieties.
          1. marcwd | Oct 15, 2005 08:29pm | #22
            Hi Piffin,
            Couldn't find anything under "conservation resource technologies" but it seems that something from Pemko should work.
            BTW, as I'm not a particularly big guy, should I be concerned about being able to wrestle the door off and (particularly) back on its hinges myself? Just not sure what to expect for the door weight and hinge realignment.
          2. Piffin | Oct 15, 2005 09:27pm | #23
            I'm only 5'9" and 155# ( the other thirty some pounds are just hanging around getting in the way, LOL) Hangina door to the hinge is more a matter of balance than of muscle and size. I use my toes but you could use a dowel or chunck of wood about halfway under the door to rock it on and fit the pin in the to hinge. After that, remove the toe or chunck, and set the other two pins. For taking oit down, you rarely ned tolift the whole door unless you are going to be working it in another room or location. Have the bench or door shoes nearby, and tilt the dor into it withg one corner on the ground.
          3. marcwd | Oct 15, 2005 11:45pm | #24
            Hi Piffin,
            It sounds like I'm about your size. (The extra thirty pounds haven't found me. Yet.) I think I understand your technique of using your toes (with a sturdy shoe on) to balance the door while inserting the first hinge pin.
            No bench or door shoes, though, for working on the door. Think I'll just prop it on the front steps.
          4. BryanSayer | Oct 17, 2005 02:59am | #25
            Occasionally, I've use a drywall kicker as a useful tool for holding a door in place to align it on hinges.
      2. calvin | Oct 15, 2005 01:05am | #17
        Wow, so many doors, and so little memory.  I'm thinking I've seen them in doors from the (maybe) 20's/30's on into the 50's.
        They were adjustible if I remember right, maybe by screwing in/out the pin that operated them.  A great place for Information, Comraderie, and a sucker punch.
        Quittin' Time
        1. marcwd | Oct 15, 2005 01:20am | #18
          Calvin,
          So what is commonly done nowadays on good quality doors to seal the gap between door and threshold?
          Marc
          1. calvin | Oct 15, 2005 01:50am | #19
            Well, the store bought prehungs are commonly supplied with an adjustible threshold.  The usual door bottom sweep has maybe a bulb with a couple vinyl sweeps.  These are usually fastened to the bottom of the door or come with a stiff pair of barbs that fit in a couple of grooves cut into the bottom of the door.
            There are still some drop down (bottom of door) or retractable (to face of door) offered.  The usual vinyl bulb on top of an oak (or other) threshold can be set.  I don't like these, too much soft stuff on the business end of the door opening, wear out/tear quickly.
            I think the ticket is the adj. thresh (composite backed).  You can make up distance for the idiosynchracies of the door install.  I have retrofitted old wood doors by installing the adj thresh and then grooving the bottom of the existing door to rcv the barbed weatherstrip pc.  Good seal, not overly bad to look at.  I also stay away from the wood insert on the adj thresh.  All metal.
            Now, for that real nice install and a bit of fitting.  You get a bronze threshold with a lip.  There's a bent brass pc you fit on the bottom of the door.  That pc slips into the thresh when you close it.  I've seen these and rejuvenated them on 30-50's homes.  Very nice.
            That's all I know, not enough high end work to see all the bells and whistles.A great place for Information, Comraderie, and a sucker punch.
            Quittin' Time
          2. marcwd | Oct 15, 2005 08:23pm | #21
            Thanks for the info about what's done nowadays, Calvin. Not sure what the adjustable, composite-back threshold you speak of would look like here. Maybe that bronze threshold would be OK but my preference is to stick with the original wooden threshold for "this old house." It does need painting, though.
  2. scrumseeker | Oct 14, 2005 01:54pm | #7
    About two years ago my door supplier sold me a bottom seal for a door that worked as described previously,  where the seal drops down when the door is fully closed.
    My supplier told me it is usually specified for dark rooms (photo development labs).
    I think the seal itself was a neoprene, or rubber material. It worked very well as a bottom seal for a custom front entry door.
  3. DonCanDo | Oct 14, 2005 02:22pm | #8
    Rather than felt, how about a piece of vinyl weatherstripping (such as a door sweep).  It could be attached to a strip of wood about 1/2" thick and then secured in the slot.
    Just another "cheap" option.
    -Don
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
