I keep having a problem with a 90+ furnace snow keeps clooging the intake pipe. It seems that it is drawing snow in and then little by little there must be a enough temperature differential in the pipe to cause the snow to form into a crusted snow block. The pipe comes up with a 3 inch 90comes up 12-14 inches and then has another 90 on top pointing straight out. I was wondering what I can do to remedy this situation.
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
Not sure I'm following the piping pattern.
Are you saying the pipe is straight out of the side wall of the house?
The pipe comes straight out of the wall then a 90 is attached and then a straight pipe comes up 12 inches and then another 90 is facing straight on attached to the straight pipe. It looks like a periscope or snorkel.
If I understand you correctly, the end of the pipe is horizontal.
If the end of the pipe was facing down then it would have a tougher time sucking up snow verses just sucking in everything that is flying by.
Are you completely sure that's not the exhaust pipe? The exhaust contains a lot of water and in very cold weather, ice can form on the exhaust outlet of a very efficient furnace. (I'm assuming you are writing "90+" to mean at least 90%-efficient furnace.)
You could try adding a fitting to turn the pipe outlet opening to face the ground, so that wind-blown snow won't get in, just in case that's the problem.
There isn't anything you can do- it is just a combination of the right conditions that cause these problems.
If there is a screen in the intake pipe- remove it.
Sometimes, adding a 3 x 2 reducer on the exhaust will increase the velocity, sending the moisture laden air further away from the intake.
If you add a 3" test tee with a plug to the intake at the furnace, you can remove the plug when the exterior pipe is frozen, allowing the furnace to operate temporarily.
Post a pic of the pipe on the outside of the house.
Very common problem with twin pipe installs in snow country. I sure wouldn't put a reducer on it or anything other than what the manufacturer suggests.
In a lot of cases the intake was actually too close to the ground (has to be above snow level) and we had to snorkel them up higher like a periscope. Some locations are a bitch what with swirling cold dry snow that get sucked in. The first thing we used to tell customers over the phone was to get a coat hanger and thrash it around inside the intake. Sometimes a fair piece up inside as it wasn't always visible.
roger
So you think I should increase the height of the pipe, what about a 90 pointing dow or a 45 do you think any of these ideas will work. It was installed to manufacturors specs. It seems that this is a common problem.
Yes it is a fairly common problem when light snow swirls around. Try playing with some fittings without glue and see what happens after all it is only used for intake air. If you have a fitting glued which you have to remove, cut the fitting off at the hub then cut the hub and try peeling off the remainder of the old hub.
This problem might not happen again. Without seeing the location there might be something you can place nearby which makes the snow not swirl as much.
The two pipes coming out (exhaust and intake) must be "in the same pressure zone" which is why they are close together.
roger
What about sending the wife out there to shovel the snow from time to time?
I'm sure he would be happy to have Your wife come out and shovel for him. Just let him know how she likes her coffee.
I have enuff problems getting my wife to do the shoveling. His is his problem. I'm here to simply present the soluiton!
just because you don't have control of your life, don't assume he doesn't
