Does anyone know of a manufacturer of a triple track by-pass system that can support the weight of solid core oak doors. We need to be able to push all tree doors to one side of the closet or the other.
Rod,
Grant Co. or Haffle.
Ed. Williams
*Rod;Hettich makes systems which will handle up to 275 lbs (for the agressive closet)Didn't see triple track, but you can take single track and lay 3, or add a third to a double. I assume you will install a trim valence, since the hangers are fairly ugly.Knape and vogt also make some hardware.I've used EB Bradley on the west coast.Adam
Ed Williams
Thanks for the reply to my msg about triple track hardware. Do you have address info for these two Company's? Ill search the web in the mean time. Rod
