I need to match a light spatter texture. Does anyone know the air pressure I should start with and how much water to mix with light weight sheetrock mud. Thanks for any and all responses…R.P.
RP, you're gonna have to experiment, but here's a starting point:
Mix your texture to the consistency of thick pancake batter, way easier to make it wetter if you have to.
Start with #30 air, use a compressor large enough to maintain pressure while you are spraying.
Now test spray on a large scrap of drywall. If no drywall is available, use cardboard, plywood, etc. If the pattern is not right, just wipe off and try again after adjusting the mud.
Here's a recent discussion on the topic: http://forums.taunton.com/n/find/findRedir.asp?webtag=tp-breaktime&mg=1DF170E1-99E0-45F2-
_______________________________________________________________
my tagline has fallen and can't get up
Yeah. Let your practice shots dry completely before deciding if they match the original well enough, too. That stuff looks a lot different when it's dry. Go lightly, you can always add, but it's awfully easy to shoot too much on initially.
Experiment with various tips on your sprayer, too. Get the wrong size blobs coming out and it won't match worth a darn.Who's the cat that won't cop out, when there's danger all about?
http://www.asmallwoodworkingcompany.com
Thin your mud just to the point it flows reliably. For a finer spray pattern use a smaller orifice and higher pressure. Likewise thicker patterns are obtained with lower pressures and larger orifices.
Good luck
"...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
