I’ve got a bunch of cable (over 2000 lbs) for which I haven’t been able to find the specifications. It is labeled
b General Cable Corp. AF30(635) 37611
It is single conductor stranded #6 wire with a two layer rubber covering, giving an overall diameter of 3/4 inch. On of the reels was marked ‘Aircraft landing lights’ and ‘1000 volt rating’. The outer insulation layer (1/8 in) seems to be a chlorinated polymer and has undergone no apparent deterioration after 5 years of outside exposure.
I want to use this cable underground to my shop. I’m pretty sure it is intended for underground use but I can’t find it listed.
Will #6 wire have too much IR drop in a 300 ft run to power a 5hp planer and 2hp dust collector together? I’ve got enough of this stuff to double every thing in the run if the guage is too light. Thanks in advance.
BJ
I've got a bunch of cable (over 2000 lbs) for which I haven't been able to find the specifications. It is labeled
It is single conductor stranded #6 wire with a two layer rubber covering, giving an overall diameter of 3/4 inch. On of the reels was marked 'Aircraft landing lights' and '1000 volt rating'. The outer insulation layer (1/8 in) seems to be a chlorinated polymer and has undergone no apparent deterioration after 5 years of outside exposure.
I want to use this cable underground to my shop. I'm pretty sure it is intended for underground use but I can't find it listed.
Will #6 wire have too much IR drop in a 300 ft run to power a 5hp planer and 2hp dust collector together? I've got enough of this stuff to double every thing in the run if the guage is too light. Thanks in advance.
BJ
