To gain steel framing experience I want to steel frame a 1 1/2 story outbuilding I’m planning. It will be a hip-roofed, insulated, windowed structure. Any ideas on where I could get a steel framed shed plan that I could use as a starting point? any other ideas for planning help? Thanks.
An FHB Podcast listener wonders if they can fix a failing foundation with PWF, the crew weighs in.
To gain steel framing experience I want to steel frame a 1 1/2 story outbuilding I'm planning. It will be a hip-roofed, insulated, windowed structure. Any ideas on where I could get a steel framed shed plan that I could use as a starting point? any other ideas for planning help? Thanks.
Isulated steel exterior walls in cold climates aren't well liked from what I gather....
Search steel framing on the web.
J
